String alignment
Re: String alignment
Postby xcaliber » Tue Mar 14, 2017 3:16 pm
robertyb wrote:I your first post you said the head and limbs. I guess you mean the riser and limbs by that. I blew up the pictures and it looks like the riser is not matching up correctly with the barrel. Pull the riser off and reinstall it being careful to match it up and see if that is not causing your problem.
That's what I see, the riser looks off square. Try what he said, just loosen it enough to make sure it is lined up snug in the channel. They should match up solid if they're lined up.
Matrix 355 (Trixxi) Redfield Revenge 2.5 Trigger Tech
Kodabow Zulu Scout (Karma) MFO Tagged Out Sights.
Hoyt Spyder 34 (Black Magic)
Postby Highcountry » Tue Mar 14, 2017 4:56 pm
Yeah I'm not touching a thing Peter is sending me new limbs. Hopefully this will correct the situation my old riser and limbs lined up perfectly. Just bad luck I guess!
Highcountry
Postby Highcountry » Tue Mar 14, 2017 5:00 pm
The riser only fits that way there is 2 tabs on the back and it aligns itself thats what I thought at first it can't be changed. Thanks appreciate the help.
Highcountry
Postby ThunderXB » Tue Mar 14, 2017 8:22 pm
Highcountry wrote:The riser only fits that way there is 2 tabs on the back and it aligns itself thats what I thought at first it can't be changed. Thanks appreciate the help.
Good call.
If that doesn't solve it, send the whole thing back to Excal to work on.
Good luck!!
380 Blackout, XB75, DM String, Dr S, TT, ti64
ThunderXB
Postby paulaboutform » Tue Mar 14, 2017 11:16 pm
It seems you've got a handle on it and Peter is more than fair to deal with. Just an FWI, even though there are two tabs in the riser that fit into the mainframe it's still possible to be misaligned. For the small effort it takes I'd loosen the riser to mainframe fasteners and wiggle the riser to ensure perfect alignment to the mainframe. You'll be able to feel the difference in alignment as you do this and it's just a good habit to have in checking your equipment.
Postby flightattendant100 » Wed Mar 15, 2017 4:28 am
paulaboutform wrote:It seems you've got a handle on it and Peter is more than fair to deal with. Just an FWI, even though there are two tabs in the riser that fit into the mainframe it's still possible to be misaligned. For the small effort it takes I'd loosen the riser to mainframe fasteners and wiggle the riser to ensure perfect alignment to the mainframe. You'll be able to feel the difference in alignment as you do this and it's just a good habit to have in checking your equipment.
Since string has downward pressure, sometimes it is easier to tell if properly seated if bow is unstrung.just a thought
Postby robertyb » Wed Mar 15, 2017 8:34 am
I would not have made the suggestion that you try it if I did not know that it could work. The picture you took clearly shows the riser is offset to the left side.
Previous
Return to Crossbow Hunting
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 35 guests
