Zombie Tough
Zombie Tough
Postby Czy_Horse » Tue Jul 04, 2017 8:59 am
First time I've ever had any arrow aluminum or carbon survive a close encounter with a 2x4 :shock:. The arrow was sticking about 4 inches out the back of the pressure treated 2x4, I removed the field point, then I using a hammer/hammer and 3/8 punch I was able to drive the arrow back out.
Only a couple light scuffs that do not show in picture. No sign of any damage at the insert/shaft interface. A couple hammer marks :roll: on insert face were easily removed with my squaring tool.
Czy_Horse
1987 Wolverine & 2009 Exocet 200- In Semi-retirement
2015 Matrix 380 Xtra
2016 Matrix 380 Lynx
2017 Micro 355 Suppressor 'SusieQ'
Czy_Horse
Re: Zombie Tough
Postby BrotherRon » Tue Jul 04, 2017 1:04 pm
I worked as an injection molding tech trouble shooting injection molding issues with various resins. Even though you can see no damage, I would have to recommend discarding that arrow. There could be stress marks undetectable to the naked eye which could cause the insert to drive back into the shaft when fired... which if nothing else could cause a "Messy" situation. :shock:
Matrix 310/330 Snuffy II~ ShadowZone ~TT~Tombstone Case.
Strings by Boo - 8ptbuk -....
http://www.freewebs.com/kingdomushers/
Matthew 25:50 & 51
BrotherRon
Re: Zombie Tough
Postby SEW » Tue Jul 04, 2017 2:51 pm
I agree with the above post; however, see how it does spin testing, especially with a long broadhead.
SEW
Re: Zombie Tough
Postby Boo » Tue Jul 04, 2017 5:11 pm
SEW wrote:I agree with the above post; however, see how it does spin testing, especially with a long broadhead.
I would do exactly that.
Si vis pacem, para bellum
boocustomstrings.com/
Random acts of kindness can change the world
Correct a fool and he'll hate you, Correct a wise man he'll thank you!
Re: Zombie Tough
Postby longbow joe » Tue Jul 04, 2017 7:10 pm
X2 if you were in a survival type situation it would be different. For the same reason when i harvest a buck with a shoulder or pass thru and hit rock ....the bolt becomes memoribilia. We spend so much on this crossbow stuff ....whats a shaft gonna hurt. I get your point and agree them zombies are tough stuff for sure!
Re: Zombie Tough
Postby wheelie » Tue Jul 04, 2017 8:40 pm
I would also throw it out. Hit bad things in 3D shoots and arrow looked fine. Next shot it broke. If you are lucky it wont break until it clears your bow!
wheelie
Re: Zombie Tough
Postby hankenhunter » Wed Jul 05, 2017 2:24 am
I agree. It's not worth the risk.
Hank
2010 Equinox The "Beast"
Big John's Zombies with helical blazers
S-5 string stoppers
150 gr. boltcutters, 145 gr. Saunders blunts
Varizone scope
Vixen master string
DaGriz knife
hankenhunter
Re: Zombie Tough
Postby Phillyarcher » Wed Jul 05, 2017 7:08 pm
I agree also with the other guys to put in the do not shoot bin. I use these arrows in the garden to prop up plants. One thing I do check all my carbon arrows at 3D shoots or when they hit another arrow is run a cotton ball up and down the shaft if it catches you no you have a damage shaft.
Excal Vortex
Excal Micro 335
NAP Spitfire Max 125 grain
Phillyarcher
Re: Zombie Tough
Postby Czy_Horse » Fri Jul 07, 2017 4:17 am
It's been scrapped :cry: better safe than sorry :wink: .
Czy_Horse
Czy_Horse
Re: Zombie Tough
Postby paulaboutform » Fri Jul 07, 2017 11:56 am
Czy_Horse wrote:It's been scrapped :cry: better safe than sorry :wink: .
Czy_Horse
Good call Brian. At least you can salvage your nock and brass insert. Torch the tip until your insert slides out then leave it in a glass jar with some acetone for a couple days and it'll come out like new...as long as it's still straight. :wink:
Re: Zombie Tough
Postby bloodtrail » Sun Jul 09, 2017 3:57 pm
Czy_Horse
Sounds like good advice to me.
I'd rather be shooting my Excalibur.
Matrix 405
Twilight DLX scope
BEZombies/Tactical Tapps
Grim Reaper SS BH
bloodtrail
Return to Crossbow Hunting
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot], Yahoo [Bot] and 27 guests
