What arrow weight do you prefer?
What total arrow weight do you prefer using in your crossbow?
350 grains
31
7%
375 grains
45
10%
400 grains
190
44%
425 grains
96
22%
450 grains
35
8%
475 grains
18
4%
500 grains
7
2%
525 + grains
13
3%
Total votes: 435
LostBolt
Re: What arrow weight do you prefer?
Post by LostBolt »
I shoot 425gr. I thinks it is the best compromise over speed and power. Super accurate in my Bulldog 380
oldm405guy
Post by oldm405guy »
well i chose 425 because what i would like to use but i use diablo with 150gn boltcutters work for me since 2014.
matrix mega 405
acp trigger
boo string
xb30 sr ir scope
joel0711
Post by joel0711 »
Exocet tested by Excalibur with 359 grains------ I went with factory recommendation--350grains
Deerstalker
Post by Deerstalker »
My 20" BEEs weigh 485 gr with 150 gr Slick Trick Mags & NuFletch Ignitor nocks.
These arrows are accurate and have the same POI as the 150 gr field points at 25/30 yards.
150 gr Slick Trick Mag BH.
Semper Fi
2012 Equinox
2012 Axiom SMF w/S5 (son # 2)
Black Eagle Executioners, 110 grain brass inserts, Blazer vanes and Lumenoks with a 100grain blade. right on 400gr. :thumbup:
Cardinalsfanforever
Post by Cardinalsfanforever »
X2, AJ. got me some executioners with 110 grn. today. My bolts for my 380 run 450ish.
Potter
Post by Potter »
The lightest possible, 350
Bulldog 440. Exocet 200
Potter wrote:
Wed Nov 27, 2019 9:14 am
I think you'll find a direct correlation to the weight of the arrows to the bows that have limb problems. And you're seeing that directly :)
You might consider upping the weight some. A couple years back Excal stopped shipping 150 practise heads and dropped to 100 as people complained they weren't getting the "advertised speed". But the numbers above suggest most people are shooting higher weights than factory
warningshot
Post by warningshot »
I’m shooting 417 grain just the combo I have set up
doegirl
Post by doegirl »
500 grains for my micro 335.
"Those who desire to give up Freedom in order to gain Security, will not have, nor do they deserve, either one."
-Thomas Jefferson
Jack Pine
Post by Jack Pine »
XX75 Easton aluminum.
390 grains for Micro 335.
460 grains for Micro 355.
Same arrow, 1 with 100 grain broadhead, the other with 170 grain broadhead.
I became a treehugger the day my climber slipped.
Art-Man
Post by Art-Man »
Gentlemen,
Does anyone have an opinion on the following. I am torn between what weight I should have on the front end of my arrows. I currently shoot a Micro 335 Kryptic Raid Suppressed Bow. I am making up some new arrows. I just ordered the Muzzy Trocar HBX broad heads in 125 grain. I also still have my QAD in 125 laying around. I was wondering what insert would you recommend the 92 grain or 110 and why. Just not sure if the extra 18 grains will make any real difference. Also has anyone had any experience with the Muzzy Trocar HBX in a hunting situation?
Thanks in advance
bigbowman
Post by bigbowman »
I only use 110gn inserts. Always ensures that my arrows have a good FOC. Good luck!
Rmturner54
Post by Rmturner54 »
My bow
Blackout BD 360
Bolts
Black Eagle Executionerw/RH offset, 18", (9gr/ in) 162 gr, OD 0.346", ID 0.300"
Insert 92 gr
Vanes 18 gr
Broadhead 150 gr
Lumenock 28 gr
Total wgt 450 gr calculated
Measured wgt 438 gr
Excal specs total bolt wgt no less than 350 grs
woolyworm
Post by woolyworm »
Is there any correlation between arrow weight and limb failure? Does a heavy arrow reduce the chance of problems? I've never had a limb failure myself, but I see a lot of people complaining that the Micro series and some of the newer bow models with higher draw weight are having a lot of problems. I see people making recommendations to use a heavier arrow (>500 grains). I would like to see some data to either confirm or refute these ideas.
