TRIGGER TECH QUESTION
JUSTANUFF
Re: TRIGGER TECH QUESTION
Post by JUSTANUFF »
I just looked at the picture I sent to TT,the trigger appears to be slightly swept forward!,,,I would post a picture here,but I don't remember how to do that.
I could send you an email,Boo?
BE Executioners 16.5 405grn
Miller Top Quiver Mounts
The base of the trigger lever is very easy to bend. Look at it closely.
JUSTANUFF wrote:
Sun May 16, 2021 5:47 pm
Yes, no problem at all. [email protected]
JUSTANUFF
Post by JUSTANUFF »
email sent,Boo.
Thanks.
JUSTANUFF
Post by JUSTANUFF »
Sun May 16, 2021 5:59 pm
I got the top one!
You definitely have the correct trigger lever. If it were me, I’d pull the trigger unit out and remove the lever and have a good look at everything including how the trigger unit sits in the mainframe before the 2 trigger unit screws are installed. Also, check the base/channel of the trigger lever with a straight edge. Like I said earlier, they are easy to distort.
JUSTANUFF
Post by JUSTANUFF »
If my memory serves me correctly,when I initially ordered my trigger I had a choice as to which trigger style I wanted,indicating to me that either one would work.
Very curious as to what has changed,or what the answer to this puzzle is going to be.
JUSTANUFF
Post by JUSTANUFF »
Sun May 16, 2021 6:19 pm
I did that as well!
Mike,
Did you get it working?
let me know when you want to go shoot it at the parkway. Steve
JUSTANUFF
Post by JUSTANUFF »
Riflemanz wrote:
Fri May 21, 2021 11:25 am
Mike,
Not as of yet Steve,I will look you up soon after!
JUSTANUFF
Post by JUSTANUFF »
UPDATE!
TT still has not come up with an answer to my problem! :roll: as to what trigger they sent me and why it won't work!
So now they are searching the whereabouts of my trigger I sent back to them,which they will polish and hopefully return soon!
NOT what I expected from TT.
JUSTANUFF wrote:
Thu Jun 03, 2021 9:07 pm
UPDATE!
Check tracking to make sure they got it, and when. Call them, email them, etc. I have reached out to them twice over the years with very quick response.
JUSTANUFF
Post by JUSTANUFF »
Thanks Dan,,it's finally on the way!
BrotherRon
Post by BrotherRon »
Riflemanz wrote:
Tue Mar 16, 2021 7:54 am
Danny Miller told me to just wipe the rail with wd40, wipe the rail dry, that's all. I have no problems.
This is basically what I do but I am using a military grade synthetic oil.
I clean the rail with it periodically and wipe it dry.
I wax my string if it starts to show any fuzz and wax my serving probably once a year during use.
I have 3 sets of strings and re-serve them myself.
Jeremiah 29:13 :thumbup:
