Salmon Candy
This area is for other topics not associated with crossbows or crossbow hunting.
IronNoggin
Re: Salmon Candy
Post by IronNoggin » Sun Jan 26, 2020 4:05 pm
mr meat wrote:
Fri Jan 24, 2020 6:42 pm
Drooling big time :thumbup: I’m surprised there’s not a line up at the door,the aroma must be great
Address is on a Need To Know basis! :lol:
However you are right - simply following your nose would likely give it away...
Due to the extreme humidity (as in constant rain) the strips took an extra day under the fans to dry sufficiently for smoking.
Had to ice down those on brine to get the temperatures right down - triple bagged blocks so as not to dilute the brine!
Final Day:
Yep, just what I was hoping for!
The waiting Big Box:
Stuffed:
1.5 hours straight heat (125 degrees) to firm up the outside, then a 3 hour burn of 50 / 50 Apple Alder chips, followed by another single hour to set.
Already smelling fine around here...
Final installment on this run tomorrow, and the start of the next...
Cheers,
Nog
Re: Salmon Candy
Post by Bcxbow » Sun Jan 26, 2020 4:28 pm
Looks wonderful Matt :thumbup:
BIlly 🇺🇸
Micro BD350 "Orion" (The Hunter)
Axe 340 (Lizzie Borden)
Trinity Strings (nchunterkw)
IronNoggin
Re: Salmon Candy
Post by IronNoggin » Mon Jan 27, 2020 1:10 pm
Wrapped up just at dusk, then let it cool on the racks for a couple hours.
Turned out Excellent!!
See through Gummy Bear consistency loaded with flavour!
And this is what 1/2 a cooler full of the good Stuff looks like:
Headed out to get the next run under the fans...
Until next time - Tight Lines!
Nog
IronNoggin
Re: Salmon Candy
Post by IronNoggin » Sat Feb 01, 2020 6:40 pm
Round Two: Into The Smoker...
:thumbup:
IronNoggin
Re: Salmon Candy
Post by IronNoggin » Mon Feb 03, 2020 1:25 pm
And That's a Wrap (literally!)
Cheers,
Nog
