How To Post Pictures.
This area is for all pictures taken in previous and current hunting seasons.
Mo wannabe
Re: How To Post Pictures.
Post by Mo wannabe » Thu Sep 27, 2012 9:15 pm
How do u do this from an I phone?
Micro 335 Camo. Micro Nightmare. Vixen Matrix 310 Axiom
Leupold scopes VixenMaster Strings
Big john arrows. BOO strings & things
Montec g5
DaGriz knive
Less work.....more hunt
Derry Hicks
Excalibur only
Deerstalker
Post by Deerstalker » Mon Oct 15, 2012 3:30 pm
When you are logged into Photobucket select View Library and hold the cursor over the photo that you want to post on the CB site. In the upper right corner of the Photobucket photo you will see a gear wheel. Selecting this gear wheel you will have the option of "Get Media Links". Select direct link and it will copy this direct link data. Go to your CB page and open your post. After you have entered your comments select the Img tab, (9th from the left) at the top of your post. The cursor will stop between,Img Img, the & ][ and you paste the Photobucket copied data there. Preview your post and your picture, (photo), should be there. Hope this helps.
Example of Photobucket direct link data.
http://i15.photobucket.com/albums/a390/ ... 200433.jpg
Semper Fi
2012 Equinox
2012 Axiom SMF w/S5 (son # 2)
Louvp
Post by Louvp » Tue Nov 13, 2012 6:27 pm
Here's a quick video showing how to post photos
http://youtu.be/qQdgs6w_ZCY
I didn't show how to upload photos to Photobucket or similar site,I'm assuming you already did that.This is just showing how to link the photos to the Excalibur Forum Post. NOTE: If you ever delete the photo from Photobucket album you will lose the photo from your Excal Forum post.
Excal Axiom SMF
Firebolts / 2" Bohning Blazers
Muzzy 125 >>>------->
Primos Trigger Stick
Nikon ProStaff 550 Rangefinder
B3,
http://www.worldclasstaxidermy.net/
hunypowell
Post by hunypowell » Mon Nov 26, 2012 9:14 pm
Thanks for the videos!
Trentco1
Post by Trentco1 » Sun May 29, 2016 11:27 pm
Please help. This is s that will come up
.com/albums/rr18/trentschwieg/E4C41C1F-2261-49F9-8076-FE748DDF3D36_zps1kv3kmdq.jpg[/IMG][/URL]
As seen no picture. Why?
Micro 355
Hawke xb30 pro scope T&T Triger boo force 10 string Zombie slayers 16.5 arrows c/w right helical blazer vanes aluminum nocks or lumenoks
Micro 315
Tact zone scope force 10 string 16" inch executioner arrows aluminum nocks or lumenoks
Trentco1
Post by Trentco1 » Mon May 30, 2016 6:39 am
Post by robertyb » Mon May 30, 2016 11:27 am
Trent,
On photobucket use the bottom link (IMG) to paste in. Then hit the Preview button to see if it worked before posting it here by hitting the Submit button.
