Chronograph
Lyn-X
Chronograph
Post by Lyn-X »
Has anyone Chronographed a ExoMax? or Exomag?
We did:
Exomax=338.6fps @3' with a 360 grain arrow, 100gr tip.
Exomax=318.4fps @3' with a 360 grain arrow, 100gr tip.
So where is the 355fps and 330fps as advertised with a 360 grain?
Thanks, :twisted: Lynn
TYE
Post by TYE »
350gr advertised, not 360.... ;)
GaryL
Re: Chronograph
Post by GaryL »
Lyn-X wrote:Has anyone Chronographed a ExoMax? or Exomag?
We did:
I is getting 332fps with the 200LB Mag with 351-2 grain bolts and 334 -+1fps with the Max and 424gr bolts..check your Chrony.... :D
Always learning!!
Home fer now!
Lyn-X
Post by Lyn-X »
TYE wrote:350gr advertised, not 360.... ;)
The Advertised 360gr is off the The arrow decision chart on X-Cals web page. The 350gr is in the X-Cal brochure. We weighed the bolt w/head it weighs 354gr on the scale.
I don't think 4gr is SLOWING the bolt that much. Lynn :twisted:
Spank
Post by Spank »
It doesn't matter, there could be a lot of circumstances, plus 338 is good enough isn't??? lol...
Lyn-X
Post by Lyn-X »
Spank wrote:It doesn't matter, there could be a lot of circumstances, plus 338 is good enough isn't??? lol...
true, just curious. i'm a Weatherby fanatic....love Velocity.........!Lynn :twisted:
chessy
Post by chessy »
yes it is nice to get the speed but i once herd on this site the only difference between a vixen and a exomag is
how much more you pull the arrow out of the dirt on the other side of a deer !!!
GREYWOLF
Post by GREYWOLF »
:D :D Mine turns in between 344 & 348 f.p.s. consitantly ! ,with a 356. grain bolt with 5" feather's. And 338 to 342 with a 365 grain bolt. But I had my rail tefflon coated that add's a few f.p.s., I will be going to a 450 grain bolt next week as our D.E.P. set that as the min. weight allowed to hunt with, I just found that out an hour ago :oops: . I dont think there will be a lot of diff. in point of impact out to 30 yard's and the K.E. will be greater though :lol: , the MAX does have a lot of power in that long power stroke!! GREYWOLF
[img][img]http://img.photobucket.com/albums/v651/ ... ing071.png[/img][/img]
1 CUSTOM EXOMAX
1 CUSTOM EXOCET 200
[img]http://img.photobucket.com/albums/v651/greywolf1/Copyofexcalibur037-1.jpg[/img]
Furor
Post by Furor »
wow 450 grain minimum seems like a little overkill, wonder what the logic is behind that. Is that for regular bows also?
Divemaster920
Post by Divemaster920 »
EXOMAG EXOCET
Looped string 419gr. arrow crono 3'
309 303
Looped string 368gr. arrow
324 315
FFF string 419gr.
309 305
FFF string 368gr.
322 317
As you can see the FFF string is faster on the CET and the Looped on the MAG. I dont know which one I will use on first day. Mag is stripped down with nothing but peep sights. Very light will use for the way back hunts. CET has all the works with one of Marks stocks also.
CD
Shakky
Post by Shakky »
Lyn-X,
I agree with you if it's advertised at 350 fps it should perform that way. If not you have a right to question why.
Ben S.
Post by Ben S. »
Moving
dw
Post by dw »
it's actually advertised at 355 fps
http://www.excaliburcrossbow.com/exomax.htm
"dw"
"you gotta love it"
Ben S.
Post by Ben S. »
moving
ch312
Post by ch312 »
ben s you piece of crap give it up with that "moving" u moron
