I decided to do a flat out comparison between BEMAN THUNDERBOLTS and GOLD TIPS LAZER II. First there is a GPI diff, froim the start. GOLD TIPS have a 8.2 GPIand a 22/64"dia.
The BEAMANS have a 10.5 GPIand also are a 22/64" dia
which means a 20" arrow weighs without inserts & vanes is a s follows
GOLD TIP ]=164 grains
BEMAN )= 219 grains
Add in inserts fronrt and rear pluss 100 gr, fielsd points ??
well beaman has more weighjt and more K.E. . and flight patterns are bot H ghreat, the BEAMON has morre KE , botH PREOPRM GREAT AND ARE DEADLY OUT TO 55 YARDS ,AS FAR AS I CAN TELL YOU LOOSE NOTINMG
WITH EITHER COMBO""AS LONG AS YOU CAN HIT YOUR TARGRT .iLL um ALL feed the freezer !!
BOLT TESTING WEEK SOME REAL SURPRICES !!
1 CUSTOM EXOMAX
1 CUSTOM EXOCET 200
[img]http://img.photobucket.com/albums/v651/greywolf1/Copyofexcalibur037-1.jpg[/img]
1 CUSTOM EXOCET 200
Re: BOLT TESTING WEEK SOME REAL SURPRICES !!
According to Beman, the front insert weighs 43 grains and the rear 37.GREYWOLF wrote:Add in inserts fronrt and rear pluss 100 gr, fielsd points ??
I too like the Bemans...but also like the Carbon express as well ..heck they shoot and hit just great!
Excalibur Micro Mag 340
Quill Bolts
125gr Slick Trick broadheads
Quill Bolts
- new paradox
