[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Configurator.php on line 5202: file_put_contents(./cache/production//s9e_renderer_34dc1ccc8ca5951b30a74bb414cf321ffe68769a.php): failed to open stream: Permission denied [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result phoenix question - Excalibur Crossbow Forum
can someone give me the length of the unstrung bow from tip to tip?
i'm hoping they(the limbs) are a bit shorter as well as the stock than my exocet.
and also ,i would like to see excalibur put a small handle on the side of the rail and on the stock portion that could be detached and put on either side about mid point. it would make carrying a lot easier in tight places with the limbs being vertical.
thanks, ls
the only this different from the exocet would be the rail length.. I think its about 1-1.5inches shorter. So yes the bow will be about 1.5 total inches shorter, but everything else is the same.
if you are looking for a short limb bow, then you will have to check into the compounds
