broadheads
broadheads
I am going on my first turkey hunt on Saturday. I am currently set up with the wasp boss broadheads that came in the right stuff pack. Will these be sufficiant or should I invest in new ones. If so which would be recommended.
Hi Sinclair and welcome to the forum.
I can not answer your question but I'm sure others here will get to it soon.
There are some bonified turkey slayers on this forum.I know of at least on fellow who used those heads to kill a turkey. here is the link
http://www.excaliburcrossbow.com/phpBB2 ... hp?t=17942
From what I can tell there are as many opinion's as there are broadheads.
Some look for pass through's while others prefer some sort of stoper on the shaft to keep the arrow in the bird.
I would imagine that a well placed shot with any broadhead would do the trick but I have no actual experiance to back that up.
Take a kid hunting
Excalibur Equinox
TruGlo Red/Green Dot
NGSS Absorber by NewGuy
Custom strings by BOO
Groundpounder Top Mount
ACF Member - 2011
Take a kid hunting
Excalibur Equinox
ACF Member - 2011
Sinclair,
I would have no issues with using the Wasp. It is very accurate and will definetely cause a fatal wound. However, as Saxman stated the bolt will probably pass through and allow the bird to run/fly off and you could have retrieval issues. They make "grapplers" that will stop the bolt from passing through causing the bird to flop around and allow you to get to it.
Rich
Rich
Use grapplers by Zwickey to stop passthrus and the bird flying off. I use Slick Tricks on GTlls for turkeys.
![Image](http://img.photobucket.com/albums/v40/Digger886/P5130001.jpg)
Digger
2-1984 Relayer,
2-1992 Wolverine
Vixen, Steddy Eddy, Varizone
Martin Rage
Martin Jaguar
PSE Infinity
2-1984 Relayer,
2-1992 Wolverine
Martin Rage
Martin Jaguar
PSE Infinity
