nock problem
nock problem
guys help me out .First I love my excocet the accurracy blows me away. I was sighting in using wasps and muzzys .i have a morrells yellow jacket target at 30 yards im burying the bolts to the fletchings the problem is ive pulled out 4 nocks using the puller .can you recommend any particular glue . i have a bottle of gorrilla glue would it be strong enough .thanks steve
excocet200
groundpounder mount
lumizone
muzzy mx4 100grains
groundpounder mount
lumizone
muzzy mx4 100grains
Gluing nocks
Gorrilla is good stuff. You might try two ton epoxey (15 min.) and make sure you clean the nock end good before reglueing. Hope this will help. Frydaddy
Yes, they have rubber on each side of small dia.steel pipe about 2" long. Pipe has been cut in two and its been welded to the pliers. Just open put around arrow close to where its in target turn clockwise a little and pull backwards. Best $12 awshucks ever spent. We used his at the last 3-D shoot pulled over 100 arrows didn't ruin any. Carbons or alum. I will be ordering mine for xmas.
well, can't get pic to post, here's the photobucket bs if anyone can straighten it out. Hate that place!!
IMG]http://i61.photobucket.com/albums/h74/a ... rrpull.jpg[/IMG]
awshucks just upload your pic to PB, under your pic high-light the third box under your pic....copy and paste in your post. It truly is easy ....awshucks wrote:well, can't get pic to post, here's the photobucket bs if anyone can straighten it out. Hate that place!!
Always learning!!
Home fer now!
Home fer now!
Defintely get the plier-pullers, and forget that silly screw-in nock remover! Those things are sold by insert manufacturing companies (or glue companies)!
Dan will send you the plier-pullers pronto. I got mine two days later!
They work like a charm. No stuck bolt is a match for them. Just position them, grasp firmly, give a little twist, and out they come!
You WILL NOT be sorry!
Grizz
