Exomag
Grizzly Adam
raydaughety
I bought an Exomag in the spring of 2003 and still enjoy shooting it today. It's a great shooting crossbow and the only one that I've ever owned. I've thought of getting a Phoenix one day as a back up but I've never had a problem with my Exomag that could be fixed here at the house or in the field. I'm not sure why they were discontinued other than to make way for the bigger, badder Exomax. I'm sure that some of the more experienced crossbow hunters will chime in and answer your questions. I think that Digger owns one of each model
. Hope I was helpful.
God Bless !!!!!!!!!
Ray
Ray
raydaughety
Grizzly Adam
The mag was a 200 lb xbow and was replsced by the Exocet 200 and the mag went on to become the max 225 lb.
The mag was introduced in 1996 till 2004. It was the big boy on the block while being produced, it started as a 185 lbthen improvements to a 200ber at 330 fps.
Digger
2-1984 Relayer,
2-1992 Wolverine
Vixen, Steddy Eddy, Varizone
Martin Rage
Martin Jaguar
PSE Infinity
2-1984 Relayer,
2-1992 Wolverine
Martin Rage
Martin Jaguar
PSE Infinity
c
Oh, I miss my Exomag.
The Best Excal so far to me. Make sure you hold on to it.
Arrowmaker - Retired
rem.exc.shooter@hotmail.com
raydaughety
Woody Williams
Originally the Exomag was 185#.
At least it was in 2001 when I first started crossbow hunting.
It is a good bow for sure.
Woody Williams
John is right, the Exomag was the best of all the Excal ever manufactured. I have one of the last Exomags made, and I can attest to that.
Even though I also own an Exocet #175 which in my mind is only second to the Mag, and a customized Vortex, which is not far behind my Exocet, I'm planning on keeping my Mag for a little while longer. I figure the longer I own it the more it will be worth.
Of course, if someone made me an offer I couldn't refuse, then I might part with it.
ComfyBear
ComfyBear Strings
To thine own self be true.
Remove thine mask Polonius.
ComfyBear Strings
bow hunter
If you bought your Exocet in 1994, it was a 165 lb bow. The Exocet became a 175 lb bow the same time that the Exomag went from 185 to 200 lbs.bow hunter wrote:I own an Exomag myself. It shoots great. Previous to that I owned an Exocet 175# that I bought in 1994. Shot a lot of deer with it. Traded up just in case I ever wanted to chase moose. Took 2 does with the mag last year. Both went less than 50 yds before expiring.
