Coyote Hunting
fuel80guy
Coyote Hunting
Post by fuel80guy »
Id like to get into coyote hunting this winter but im unsure of what equipment to get.
I want a rifle i can use on deer as well and the calibre has to be below.275 to fall within my local game laws.
I need some help on ballistics as i know nothing about rifles.
I also need some help on mouth calls which type is preferred and why.
Im also looking to get a quivering rabbit decoy as i already have a renzos varmint decoy kit.
In short i got a real thing for these coyotes after being chased down by them this fall while dragging out a deer,,,its personnal now :D
Any help would be greatly appreciated.
Pydpiper
Post by Pydpiper »
Sounds like a .243 may be your rifle, I would do a .270 though if I didn't have a dedicated varmint rifle.
For a decoy I use a "rigor rabbit" cost about $15 and works like a champ! Mouth calls, I use a howler by Mad Calls, and a squeaker out of an old kids toy. Last year this put a coyote in my lap, close enough to make me bleed, him too though.
I have been using a cottontail in distress call but have not had very good luck with it so far.
It may be the sounds you're making with it. It's impossible to describe the sound, but I learned from a cat. He had caught a cottontail, and the sounds I was hearing had me totally baffled until I looked outside and saw what it was. It was nothing like the "how to call" tapes you could buy back then. It was a frantic series of high volume - short duration calls that sounded just like a cottontail with his a$$ in the jaws of a predator! :lol:
The calls would go on for a very short time, then the cottontail would be quiet. The cat would give it a minute, then release it and then re-capture it as it tried to escape - then - a repeat of the screams!
I went out that evening (summer time) and set up in a logging road where I knew gray foxes were close. One series of calls and a fox almost ran over me!
Not all sounds will work in every location, and a lot of places have been over hunted and animals have been educated to calls, but the cottontail distress is still my #1 call to try first. :wink:
If you want to PM me with your phone number and a time you will be home I'll call and let you hear the sounds I use. (best done when my wife isn't home :lol: )
ninepointer
Post by ninepointer »
Depending on where you're hunting in Niagara, check out the municipal firearms discharge by-laws. Many are more restrictive than the Provincial reg and do not allow rifles whatsoever. As far as I know, rifles less than .275 are OK in Haldimand.
Big John's Custom Arrows
Groundpounder Quiver Mount
fratri
Post by fratri »
I started out with a 270 here in southern ontario, I have since turned to the 223 for coyotes, the 270 just did to much damage to the hide..... I made myself a home made e-caller from varmint als, works great and as some others have already mentioned use the rabbit in distress call.....I place the call about 80 yds or so away in the middle of the field, turn it on and hide on the edge of the bush, You can get some real quick action, some up close and personal....most coyotes will come in right away, first few minutes anyway, I did have one come in after my 25 min sequence of the dying rabbit finished and it started playing a crow frenzy call, so you never know, get out there and try it, you will have a blast......
Varmint Als is worth the read....
http://www.varmintal.com
Grizzly Adam
Post by Grizzly Adam »
If it was me doing the choosing for a combo predator / deer rifle, I'd choose a .243, because of the low recoil, accuracy and flat shooting. Plenty of soup for coyotes, and enough for deer, when used judiciously.
But that's just me. :D :wink:
Grizz
Coyote calling can be fun. Taking a few big hairy ones out of the equation would ease the stress on the deer population. Rabbit in distrees mouth calls are probably a favorite for many varmint hunters. A moving decoy adds reasurance to a hungry one looking for a easy rabbit meal. Using varmint bullets like the Hornady V Max or Nosler Ballistic Tip seam to anchor them with authority from most of the varmint calibers such as the .204, .222, .223, .22-250, .220, .243, .257.
Good luck
You may want to check out the fine quarterly publication:
www.varminthunter.org
Highly recommended.
Pydpiper
Post by Pydpiper »
enormous wrote:You may want to check out the fine quarterly publication:
Highly recommended.
I second that. :D
ger34
Post by ger34 »
personnally..I like the 25-06...a little heavier so it doesn't get blown around in those stiff February winds...but still shoots like a laser....also..it is essentially a necked down 30-06.....so resizing some 30-06 brass is the easiest way to reload....just an opinion
On the other hand.....I work with one of the shooters from this video
http://www.predatorhunters.com/video.html
he uses a custom made .17 Javalina....small hole...and after watching the vid? obviously very good for shooting 'yotes and all varmints in the wind
just my 2 cents
Summit Viper SS
Gold Tip Laser II
4" vanes
100gr G5 Montecs
Fergie10
Post by Fergie10 »
ger34 wrote: On the other hand.....I work with one of the shooters from this video
just my 2 cents
wow sign me up i need to do that one of these days
DrDan
Post by DrDan »
I like 17 Remington especially in areas on border of residential areas. Never need to worry about richochets. Once that 25 grain bullet hits anything at 4300 fps it vaporizes. I use the Jack in Box decoy and some hand calls. I'm a call freak so I have several but my favorite do it all call is called a Verminator Tweety. It is only about $6 to $8 from Cabelas and can do anything from rabbit death to interrogation howl. Amazing little call! I had three or four calls in my lap and the salesman came along and said, "Put them all back and I'll show you something that will emulate them all" It turned out to be my favorite and I always carry it!
Phoenix - Equinox
Don't trust anyone wearing a necktie...
DrDan
with the deer thrown in .243 or .257 Bob would be just the ticket
