what position will cause you to pass the shot .. ?
good afternoon bowhunters : my question - I have heard tell that it is not a good shot to shoot dead on; quartering toward you; straight broadside... straight down cause you can hit the back bone....
so : what is your opinion ...
what shots would you not shoot ... not take the opportunity .. and what would make a difference and allow the shot , if anything ? if the head used would make a difference or the arrow weight anything I would like to know your thoughts on it...
thanks...
dk
thanks...
dk
life guard at the gene pool
straight down and straight broadside are probably the 2 best shots you can take
straight down drops the deer instantly 98% of the time
I actaully like straight on shots, but not with a bow though. With a slug or blackpowder gun the effects massive
the only shot I dont really like is a quartering towards me. It can work, but its also a big chance of hitting nothing but shoulder, or you hit to far back. It all depends on how confident you are as a shooter.
Ive actaully seen some bad shots, end up good. Like some hindquarter shots that killed the deer in seconds, but those were good shot situations that the shooter pulled badly
![Laughing :lol:](./images/smilies/icon_lol.gif)
I dont have any hard fast rules for shots.
If I dont get that warm fuzzy feeling about a shot then I wont shoot.
I killed 2 this season quartering to,they just felt right and they were.
Take a kid hunting
Excalibur Equinox
TruGlo Red/Green Dot
NGSS Absorber by NewGuy
Custom strings by BOO
Groundpounder Top Mount
ACF Member - 2011
Take a kid hunting
Excalibur Equinox
ACF Member - 2011
From ground level quartering hard towards me or facing directly away is a no go. There is nothing you can change in your crossbow setup to make those shots reasonable in my opinion.
Broadside and quartering away are obviously gimmes. As Phoenix_Tom said, every other angle is a judgement call taking into account a myriad of factors at that moment.
While it is generally a bad idea to take a strait on shot, I took the shot this year with my crossbow of all weapons. I dropped a doe in her tracks.
Precise arrow placement can turn a less than optimal angle into a golden opportunity. An average hit will sometimes work out if taken from a good angle. An average hit is normally not good enough if take from a bad angle. It takes perfect arrow placement to humanely harvest a deer from a poor angle.
Won't be taking any shots while the deer is just coming out of a ditch, you know that two feet on the road and two feet still in the ditch look; with about half the body level for a shot and the other half too low to the ground cause of the ditch.... A valuable lesson learned.
I agree with other posts, the best option probly along the lines of being completely broadside.
Mike P wrote:Missionary.kennisondan wrote:Re: what position will cause you to pass the shot .. ?
![Image](http://i166.photobucket.com/albums/u104/trudi123/emoticons/OMG.gif)
with the bow it would have to be broadsided or quartering away
http://www.hunter-ed.com/sc/course/ch4_ ... _shots.htm
