Pulled out flat nock
Ibex
Post by Ibex »
Hi everyone,
I am the new owner of an Ibex. I put it together, lubed the serving, mounted a scope and in 3 shots was hitting the center of the bull at 20 yards. Amazing.
Anyway, I was removing a Firebolt from my "Block" using the arrow removing tool I made and pulled the nock out of the arrow.
Do I need to clean up the nock or inside of the arrow, and what glue do I use to glue it back in?
Fran
frisky
Post by frisky »
Welcome to the best forum .
2007 Phoenix
Custom Wood Stock
Gold Tip II 311 Grain
Boo Astroflight String
Varizone Sighting
lscha
Post by lscha »
Hi Ibex!
WECOME to the forum! And,
oh yeah, the "I'm the new owner of an Ibex club"!!! :lol:
Laura
Camx
Boo strings, top mounts
Pydpiper
Post by Pydpiper »
Q-tip with isopropyl alcohol to clean it up, then some super glue will slip it right back in. Spin it as you insert it to spread the glue evenly.
If it were me I would want the same glue as what it once had, but I truly do not know what that arrow is made of.
roly
Post by roly »
Welcome Mr. Ibex ,you will like it here!
I use hot melt but I don't know if that is correct. :)
Limbs and Sticks
post sub
Post by Limbs and Sticks »
Welcome IBEX people :) just like pyd said. I use goat tuff glue good luck.
Wes
"Maxine"
1.75x5 Burris scope
STS
Feathered easton 2020's
Magnus stingers
Wishbone
Post by Wishbone »
Welcome Ibex lots of good folks here. Congrats on your new bow.
Every moment in the woods is a gift from above, having the Excalibur with is a blessing...
cdup
Post by cdup »
Welcome to the forum! :D
Respect everyone, but fear no one
sumner4991
Post by sumner4991 »
If you never ever want it to come back out, then use gorilla glue. You will be stuck with it then. Very small amount, it expands. Warning . . .it never comes out.
Welcome!
mikej
Post by mikej »
welcome
Welcome to the forum. I have also used crazy glue to glue in the inserts. Then I am able to remove the bolts from the block target without the inserts coming out. The tool I made threads into the rear insert. I have read on the forum here that there is someone who has made an improved bolt removing tool. The name escapes me at the moment, but one of the good folks here will fill in the blanks :)
Chris Dillard
Post by Chris Dillard »
Welcome to the Forum.
2014 Vixen II
2006 Exomax
Pydpiper
Post by Pydpiper »
Danny Miller makes the puller that you want, it is the best when it comes to pulling arrows without damage.
BUS314
DAN
Post by BUS314 »
Dan Miller remover tool --740-483-2312
Grizzly Adam
Post by Grizzly Adam »
Pydpiper wrote:Danny Miller makes the puller that you want, it is the best when it comes to pulling arrows without damage.
Welcome to the forum, Ibex! :D
Get yourself a pliers-type puller from Dan. You won't be sorry! 8)
Grizz
