tree stand height
tree stand height
my tree stand is 12 ft off the ground my son's is 15 ft off the ground. how high do you hunters go off the ground.
m
Our stands are at 20 to 22 feet up. Once in a while a few feet higher but mostly around 20 ft.
Arrowmaker - Retired
rem.exc.shooter@hotmail.com
- one shot scott
how high
it all depends on the cover and were you are hunting .ie if on a fence row you do not need to go very high 10 feet will work in thick bush you may not be able to see at 10 feet you may have to go higher or lower .i try to go high enough to have some cover but only as high as needed most times 12 to 15 feet will do on a verythin fence line i go higherto get some cover .stand were the deer will be and look around try to find a tree that will give you sme cover behind you so you can move and draw .DUTCH
addicted to canadian beaver
Re: how high
dutchhunter wrote:it all depends on the cover and were you are hunting .ie if on a fence row you do not need to go very high 10 feet will work in thick bush you may not be able to see at 10 feet you may have to go higher or lower .i try to go high enough to have some cover but only as high as needed most times 12 to 15 feet will do on a verythin fence line i go higherto get some cover .stand were the deer will be and look around try to find a tree that will give you sme cover behind you so you can move and draw .DUTCH
X2 that is exactly what I was going to say..
tree stands
the higher you are the harder thy are to hit .the kill zone gets very small when you get high DUTCH
I go as high as the best cover.. but even with that, I wont go past 18ft
90% of my stands are 12-15ft and Ive never had issues with being seen or scenting as long as the winds right. The trick is trimming for stands early or even right after season goes out. That way deer have PLENTY time to get use to things. Dont trim more limbs than needed!!!! Live by that rule
plus I hate heights, so im not going past a level that I feel safe at
