slick trick cutting diameter question.
- truckintravis
just recieved my equinox monday and my laser II bolts 20" with brass inserts and 4" vanes. I bought slick trick 100gr. standards. Threre 1" cutting diameter, should I go to the 1 1/8 instead ?
- cholafxsti
- one shot scott
sumner4991
Bob . . .you and I agree on a few things, this is certainly one of them.bstout wrote: I have little use for the tiny heads.
It's not as much an issue of the small heads as it is an issue of total cutting surface. For example a Slick Trick 1" has 4 blades doing the cutting. Another broadhead may offer 1.75" cutting diameter, but, only have two blades and the little bleeder blades. You would have to measure the cutting area to see if there is really a cutting difference between the broadheads.
You want the most cutting surface. That isn't always the largest cutting diameter.
