Rubber boot repair???
chris4570
Post by chris4570 »
I discovered after my Sundays hunt that I have punctured the sole of my Lacrosse Burly ATSs. Any suggestions as far as the best method of repair??
I was thinking, silicone or a plug for an automotive tire. My guess is the silicone won't last, and the plug would be uncomfortable on the inside, even if I could trim it down.
"It CAN Be Done!"
Michihunter
Post by Michihunter »
I use Shoe GOO. Comes in a large tube. Works for me. Put some on my rubber Lacross boots three years ago and its still holding up. Most chain sporting goods have it, Meijers, etc. A good adhesive slicone should work just as well though.
Hoss
Post by Hoss »
I use the shoe goo on my alhpa burlys Chris it works good..
DanO
Post by DanO »
Yup, shoe goo or aquaseal (wader repair stuff). Both work as well as anything. I think it depends on where the leak is found. If it's a flex place on the boot, good luck.
Dan O.
If you're not part of the solution, you might be part of the problem.
chris4570
Post by chris4570 »
The leak is around the ball of my big toe, in the sole. A small hole.
Where can I get shoe goo? And is marine goop the same idea/thing?
"It CAN Be Done!"
Try Canadian Tire or even Wal-Mart.
Hoss
Post by Hoss »
chris4570 wrote:The leak is around the ball of my big toe, in the sole. A small hole.
I think it is Chris..it smells and looks just like it..ive used both they seem to be the same to me..they both work well..
B-Logger
Post by B-Logger »
Yes, it is the same thing. I think they are all the same; just named different. The good thing is the patches last a long time.
Keep smiling!
Dennis
ob
Post by ob »
Goop is good stuff. I repaired my winter (rubber) hunting boots with a good dollop of it about four years ago and it held just fine.
ecoaster
Post by ecoaster »
It is great stuff. I have repaired neoprene waders with Goop and it is still holding, years later. Canadian Tire will have it.
chris4570
Post by chris4570 »
UPDATE: Shoe goo to the rescue!!! So far it is working great. My feet are staying dry and I have 99.5% of the tube left.
"It CAN Be Done!"
Dereck
Post by Dereck »
That stuff is awesome used it to repair boots,tent, jacket always have a tube when away from home hunting.
Tenpoint Matrix
