..........and the bolts basically MELTED the foam. They were stuck as solid as can be, with the foam melted right onto the shafts. That was with field points and eventually I did get a leather glove around the shafts and worked the bolts out with a set of channel-lock pliers. The bolts are covered with cooked-on styrofoam.
So I need a different target to use with carbon bolts, and I want something that I can use for broadheads. Any suggestions?
THANKS!
