Orginial Exocet
catkicker
Orginial Exocet
Post by catkicker »
I bought my Excalibur Exocet about 9 yrs. ago. I cannot find my orginal paperwork on the bow and wondered if anyone had the complete specs. on the original exocet.
I'm thinking about passing it down to my 11yr. old son. We have his first Whitetail hunt planned for next season. This bow looks as nice today as the day I bought it 9 yrs. ago.
Alli knowed it they were carved tip limbs & 165 LB. using dacron strings came with cast flat riser like my vixen
ComfyBear
Post by ComfyBear »
Excaliburs Exocets manufactured circa 2000 had the following specs:
Velocity = 270FPS
Draw Weight = 165lbs.
Power Stroke = 15"
Mass Weight = 6.1lbs.
Overall Length = 38"
Arrow Length = 20"
Arrow Weight = 400 Grain Min.
Finish = 3 Colour Camouflage
ComfyBear
ComfyBear Strings
To thine own self be true.
Remove thine mask Polonius.
catkicker
Post by catkicker »
ComfyBear wrote:Excaliburs Exocets manufactured circa 2000 had the following specs:
Velocity = 270FPS
Power Stroke = 15"
Arrow Length = 20"
Thanks ComfyBear.
BIG difference between the old and the new Exocet. I don't know that there is much I can do to increase it's power. Time to start looking around for my next Excalibur.
mikej
Post by mikej »
Velocity = 270FPS
Power Stroke = 15"
Arrow Length = 20"
Thanks ComfyBear.
you can add mag tips limbs to after mag tips are added you can add a fast flight string. you can also shim the riser to equal the newer forward risers
ninepointer
Post by ninepointer »
Velocity = 270FPS
Power Stroke = 15"
Arrow Length = 20"
Thanks ComfyBear.
More power? My Exocet 165 has passed arrows through deer diagonally! :lol:
Big John's Custom Arrows
Groundpounder Quiver Mount
GaryM
Post by GaryM »
mikej wrote:you can add mag tips limbs to after mag tips are added you can add a fast flight string. you can also shim the riser to equal the newer forward risers
I replaced my '97 Exocet limbs with new carved tip limbs last year. I didn't shim anything though. No one told me to do that. :( Tell me what to do and how to do it. Thanks, Gary
Mike P
Post by Mike P »
ninepointer wrote:
Velocity = 270FPS
Power Stroke = 15"
Arrow Length = 20"
Thanks ComfyBear.
But the higher power Exocet will bury the arrow deeper in the dirt after the pass through ninepointer. Get with the program! :wink:
ninepointer
Mike P wrote:But the higher power Exocet will bury the arrow deeper in the dirt after the pass through ninepointer. Get with the program! :wink:
How could I be so foolish?
Catkicker, thanks to MikeP and his ever-present wisdom, I've realized that your old Exocet is in fact way too under-powered for you or for your son :wink: Deer are far tougher nowadays than they were in the 1990's.
My advice is get rid of that crossbow. Feel free to contact me about my "Cash for Clunkers" program :wink:
Better yet, donate that old Exocet to the Excalibur Kids program! :D
ComfyBear
Post by ComfyBear »
The difference isn't as BIG as you think, when one compares apples to apples. The 270FPS speed is obtained using a 400 gr. arrow. With an Exocet 200, (even using a fastflight string) if the same weight arrow was used, its speed would be nowhere near the 330FPS "advertised speed".
Its realistic speed would be a lot closer to 300 than to 330. :shock: :wink:
ComfyBear
ComfyBear Strings
catkicker
Post by catkicker »
So is it worth the $$ to get a set of mag tips and fast flight string?
roland
Post by roland »
I added the shims, the mag tip limbs and I added a block on the end to give me more draw length. It is a 1993 exocet.I got all my info from Enormous,many thanks, I also put a flemish string on it. it works very well.
jay73
Post by jay73 »
roland wrote:I added the shims, the mag tip limbs and I added a block on the end to give me more draw length. It is a 1993 exocet.I got all my info from Enormous,many thanks, I also put a flemish string on it. it works very well.
Roland, could you post a pic of your set-up please?
Jay
catkicker
Post by catkicker »
Pics would be nice.
awshucks
Post by awshucks »
Dunno about that Cbear. My Y25 w/ Boo gets 311 fps w/ 400 gr arrows and the Boo costs me 8-9 fps vs FFF.
