Another question on inserts
- trailcamguy
I have several 2216 arrows for the vertical bow. Can I use a regular aluminum insert that I already have, or does the insert for the fletched end have to be crossbow specific ? I'll use brass inserts on the business end, but thought I would just use up the aluminum inserts if they will work.....thanks for the input...don
Re: Another question on inserts
You can leave alum. insert in either end just bevel the edge so if used on rear it won't cut into yer serving!
- Limbs and Sticks
X2
Wes
Wes
"Maxine"
1.75x5 Burris scope
STS
Feathered easton 2020's
Magnus stingers
1.75x5 Burris scope
STS
Magnus stingers
X 3
wasp sst hammers
groundpounder
lumizone
ff string
wasp sst hammers
groundpounder
lumizone
ff string
- trailcamguy
Makes perfect sense, I'm still green at this and hadn't considered the bevel and string contact...That's why I asked the experts !!
How much of a bevel would you put on the insert and what would you use to bevel the insert?
Thanks,
Raymond
Thanks,
Raymond
shaftthrower
I use a fine file then 400 or 600 sand paper.Raymond wrote:How much of a bevel would you put on the insert and what would you use to bevel the insert?
Thanks,
Raymond
As said above, most the time i just take a sheet of sandpaper flat down & rub arrow with insert on it til its no longer an edge. I also use a reloaders chamfer tool alot when doing more than a few. Used on brass cases fer inside & outside chamfering.
Thanks for the response. Much appreciated.
Raymond
Raymond
Thank you bstout.
Raymond
Raymond
Ah yes, nothing like a good rock to help with them arrows eh Bob!
You only need a very small bevel. and you may have a problem with Brass fitting the front properly.
Check one for play and sloppiness first. Should fit very snug to start.
Arrowmaker - Retired
rem.exc.shooter@hotmail.com
- trailcamguy
Thanks everyone. Appreciate all the response.
- Limbs and Sticks
John wrote:Ah yes, nothing like a good rock to help with them arrows eh Bob!
Goldtip brass inserts fit 21series exc. with the 2219 or 2216 the brass doesn't fit that well from goldtip, I think someone does make them for the 22series, Rock On
Wes
"Maxine"
1.75x5 Burris scope
STS
Magnus stingers
1.75x5 Burris scope
STS
Magnus stingers
A thank you from me also, for all the support.
Raymond
Raymond
