Folks,
How the heck do you get the nock out of a carbon bolt? I read a post for aluminum botls that suggested screwing a field point in the nock, heating the point with a torch, and using pliers to pull it out. Can I do the same for the carbon bolts.
Installing Lighted Nocks in Carbon Arrows
Re: Installing Lighted Nocks in Carbon Arrows
You got it, screw in a field point get a good set of pliers and pull it out , you will not need any heat at all to do this if you are not strong enough get your wife to do it LOL . As well depending on the brand of nock have some sand paper about 200 grt sand the end as to remove any glue, as well sand inside the shaft not to much make sure the nock matches the arrow diametor, take your time and you will have it done without any problems . All the best
If I was any better they would have to beat me sensless with an ugly stick
On the fire bolts I noticed when useing the Nap quick twist
That when putting them in the boiling water the nocks came out
I love super glue
I love super glue
May my aim be true and my arrow fly straight
Micro 335 (Porky's Piglet)
Stock string
Quill
125 grain ACTs/Boltcutters
MagAir
Stock string
Quill
125 ACTs/Boltcutters
Stock string
Quill
MagAir
Stock string
Quill
Screw the field point into the nock and heat and pull until it comes out.
After the shaft and glue cools down, if you've got a .38 cal wire bore brush, run it in and out the end of the shaft to get the remaining glue out. This should do it.
Screw in a field point,Heat field point over boiling water and pull with pliers,comes out real easy.
