Box call chalk
Box call chalk
Has anyone used a substitute for chalk? I was thinking that rosin should do a better job than chalk.
Re: Box call chalk
If I remember correctly, the Knight & Hale turkey box chalk has rosin in it.
S5 System
Shadowzone
S5 System
Shadowzone
Re: Box call chalk
I don't know, straight rosin may be a little too "sticky" for a call. A little may be OK, but the straight stuff may not be good.
I mainly use pot type calls, but keep a box call in the vest in case the turkeys want something different. Because of it, I don't use very much chalk.
Re: Box call chalk
When I play ball I use rosin on my hands
It tends to build up and get sticky
it may not react the same on wood as it does skin
But dirt does stick to it
The grandaughter leaves piles of sidewalk chalk
here so I have an endless supply. I just can't take
her favorite colours.
Re: Box call chalk
Be a man, steal all the pink ones! LOL j/kroly wrote:The grandaughter leaves piles of sidewalk chalk
Re: Box call chalk
VERY good!!wheelie wrote:Be a man, steal all the pink ones! LOL j/kroly wrote:The grandaughter leaves piles of sidewalk chalk
Re: Box call chalk
I've tried various sources of chalk for my box calls.
Even tried chalk powder like the stuff used in construction chalk lines.
Finally settled on the kids sidewalk chalk.
If the box call gets wet then simply wipe dry and apply a fresh layer of chalk.
I have one slate that I rub with the chalk and it softens the pitch.
The rosin will just gum things up and removing would require a solvent.
Re: Box call chalk
Nobody steals from a granddaughter, a daughter maybe.wheelie wrote:Be a man, steal all the pink ones! LOL j/k
Re: Box call chalk
I'm allowed the pink oneswheelie wrote:Be a man, steal all the pink ones! LOL j/kroly wrote:The grandaughter leaves piles of sidewalk chalk
Can't touch the Purple, Green or yellow.
Re: Box call chalk
Just do not use chalkboard chalk, it contains wax.
S5 System
Shadowzone
S5 System
Shadowzone
Re: Box call chalk
Hey Don,
I use rail road chalk, you can but it on ebay or your finer sporting goods stores. You need to stay away from chalk that has wax in it, it will damage your call. It put's wax in to the wood and you have to sand alot to get it out, it change's the sound of the box. Stay away from the chalk that they used in school on the blackboards.
God Bless,
Mark
God Bless,
Mark
I walk in the light with my Lord and Savior!!!
2011 Excalibur Vortex with a Twilight DLX Scope
Boo Custom Trigger
Gold Tip Laser IV's
100gr. Swacker Broadheads
Onestringer Arrow Wraps, with Blazer Vanes
Equals a Deadly Weapon!!!
Boo Custom Trigger
Gold Tip Laser IV's
Re: Box call chalk
railroad or sidewalk chalk..... or old school chalk, it don't have wax
and thats why its not used in schools anymore.
i'm glad i hava bunch in supply...........
2013 matrix 380x
2011 vortex
vintage exomax & exocet
boo custom strings
Burris FF-III
RBBB
L&S speed demon arras
Easton xx75 2219ch
Ignitors
125 G5 striker mag
Dalton wax
bowmax 1131
wabi calls
I prefer dangerous freedom over peaceful slavery.
2011 vortex
boo custom strings
Burris FF-III
RBBB
Easton xx75 2219ch
Ignitors
125 G5 striker mag
Dalton wax
bowmax 1131
wabi calls
Re: Box call chalk
Maybe some may know and maybe some don't,
Chaulk for box calls is really used to draw out any moisture that maybe in the wood allowing for a better friction. Most box calls can be used without chaulk and nthey will still run, but damp days with moisture in the air a box call will suck it into the wood and break down starts.
You can also use it on a slate call as slate is pourous material and also will exsorb moiture and the chaulk will help dry out the material faster.
Its the oil content that a user has to watch out as chaulk board chaulk has oil in it. Once oil is exsorbed into the calling material it near impossible to get rid of and will cause sliding in that area.
So this is why a caller wants chaulk on their calls is just to dry up the material for better friction....
Ontario Hunting Lodge
http://z13.invisionfree.com/Ont_Hunting_Lodge/index.php?act=idx
- EQUINOXHNTERVA
Re: Box call chalk
I have a primos wet box call that doesn't require chalk at all. https://shop.primos.com/p-915-wet-box.aspx I assume this is what your speaking of when you say rosin.
2009 Equinox, Easton Powerbolts, S5 system, 100 gr. spitfires. Judging a person does not define who they are. It defines who you are.
