oh no help!!!
oh no help!!!
Shooting the Excalibur tonight and all of a sudden arrows are flying everywhere.... smallest group I can get is 4 in at 20 yds. With field tips Muzzy, rage practice, or montecs. I brought it in and checked it over and all the screws were loose dealing with the scope mounts. Seems its vibrating them loose. I tightened them down and groups shrank but still not what it used to be... any ideas? I checked and tightened all the screws I could see bit nothing...
GAMIKATSU///Edward
Excalibur MEGA 405
440 GN BE Zombie Slayer
379 FPS over prochrono digital
140 Foot Lbs Kinetic Energy
Excalibur MEGA 405
crazyfarmerHD
Re: oh no help!!!
the scope coming loose wouldnt have thrown the bow off.. you may be just wore out so go back and try again tomorrow;)
u can just a small drop of lock tite (medium) on those if you want. Mine came loose before also. Just re sight it in after you get it a break.. when things go wrong, we get paranoid and its not what they seem to be. If you cant get 1-2inch groups with a solid rest tomorrow let us know
aka crazyfarmer
Deer Whisperer
custom cowwackerz
Deer Whisperer
custom cowwackerz
Re: oh no help!!!
You're using a rope cocker, right?
Re: oh no help!!!
Generally when they start shootin all over like that its scope/rings/mount problems
Re: oh no help!!!
Rope cocked yes. I rested for two hours. Going out to shoot some more now. Switching to different arrows just to rule those two I practice shoot with. I'm anal and the bow shop only had fire bolts in yellow FL etching and not orange like the rest.
GAMIKATSU///Edward
Excalibur MEGA 405
Excalibur MEGA 405
Re: oh no help!!!
Got to shoot my vortex today and mine that was making an od sound semms to be fixed scope never came lose though thinking about loctiting all the screws now.Hope all goes well!
Re: oh no help!!!
tightened everything, back to stacking arrows. thank goodness. i was scared. a lot of twang/rattle is dissepated as well. guess i get to blue loctite everything. i did learn, that it does NOT like Firebolts tipped with Muzzy 3 blade 100 gr. sprays them like a shotgun. if i use a Lumen arow (lumenok branded arrows) with a brass insert it punches them very tight. guessing a FOC issue with the light weight firebolts.
GAMIKATSU///Edward
Excalibur MEGA 405
Excalibur MEGA 405
Re: oh no help!!!
Blue loctite all the way for me. That means all hardware except for the scope rings.Gamikatsu wrote:tightened everything, back to stacking arrows. thank goodness. i was scared. a lot of twang/rattle is dissepated as well. guess i get to blue loctite everything. i did learn, that it does NOT like Firebolts tipped with Muzzy 3 blade 100 gr. sprays them like a shotgun. if i use a Lumen arow (lumenok branded arrows) with a brass insert it punches them very tight. guessing a FOC issue with the light weight firebolts.
Re: oh no help!!!
No panic here as I know my bow.hankenhunter wrote:I know the feeling. It's like your bow is one of your kids. When some thing goes wrong, it's panic time. At the very least a strong show of concern. Am I Right everyone?Hank
Pretty easy to track down the annoyance on an Excal.
Re: oh no help!!!
if i could only get firebolts to shoot muzzys... i think i'm going to take one, and pull the insert out... replace with a brass insert... and see how it shoots.
GAMIKATSU///Edward
Excalibur MEGA 405
Excalibur MEGA 405
Re: oh no help!!!
Never Panic its an Excal! Someone will knowed what to tell someone who needs help wid them. Some of the Folks on here have had Excals long as they been sellin them
- maine hunter
Re: oh no help!!!
i would have paniced too. when you have something and it going great, then when it doesn't, makes you wonder what heck happened.
crazyfarmerHD
Re: oh no help!!!
I tried to pull the inserts out of mine and pulled half the carbon out with them.. They use some string glue in those firebolts
but yes the FOC can cause issues and thats probably it.. I could get muzzys to group well with any arrow combo though but others have good luck with them. Muzzy was the only one I used for years and years but had to switch.
aka crazyfarmer
Deer Whisperer
custom cowwackerz
Deer Whisperer
custom cowwackerz
Re: oh no help!!!
Glad you sorted it. Once you get to know your bow well, any change in sound/vibration is a sure sighn something is loose or not right. Its then just a matter of feeling around and isolating the culprit giving you trouble.
Re: oh no help!!!
Gotta ask, why not just use Boltcutter bheads w/ your Firebolts? They were designed to go together...........
