Vortex Bolt speed?
WTBJR
Vortex Bolt speed?
Post by WTBJR »
Finally, after three years of LOVING my Vortex, building my Bolts and harvesting eight, real nice whitetails with nothing, but GREAT results, I got the chance to Chrono my set-up.
My bow has about 100 shots on the limbs and maybe five dry fire (first four shooting sessions three years ago). i wanted to post the numbers and ask the Experts here, how they are in comparison to other "set-ups".
My "Set-up" is;
Excalibur fast flight string with 50 shots, brace height, 3/16" above line (closest to shooter) on rail. My bolts weight 404 gr. The shafts are Firebolts with 2'blazers fletched with the Arizona E-Z fletch helical. !24 gr field tips with 25 gr Aftershock BH Boosters.
Yesterday I had access to a "top-of-the-line" Chronograph.The weather was mild 55f, moderate x wind and partly cloudy.
I shot maybe 13 times and all 13 were 313 fps. The chrono was six feet in-front. I had not been able to shoot my bow past 40 yards and with my site in at 20 and the speed ring set on, a little above the 325 mark. At this set-up I was expecting to have to adjust the speed ring to 313fps for my poi to be spot on at the 50 yard chevron on the varizone .
I moved my target to 50 yard and two shots (313fps were spot on. I then moved out to 60 yards and the "bolt fell from the sky". 50 yard chevron and poi was 10-12" low. At 50 yards i was stacking the shots and at 60 ALL OVER THE BAG.
My question to the "Much more experienced than I", Are these results normal for my set-up? What should I expect from these bolts weights? What kind of accuracy and range can I obtain with this bow, and what bolt weight should I use for "long range target shooting"? I like the 404 gr set up I have with heavy FOC for hunting. If I go with the Executioners my bolts will weight about 414 gr
Thanks for any and all help in advance
Bill
nchunterkw
Re: Vortex Bolt speed?
Post by nchunterkw »
Sounds in the ballpark to me. I too shoot the Vortex and own a chrony. I have found the "5:1" rule to be accurate with your setup (FFF string). By that I mean you lose 1fps for every 5gr of arrow weight. Excal advertises 330fps with the FFF string and a 350gr arrow. Taking your bolt weight(404) minus the advertised 350 = 54 grains. Divided by 5 = 10.8fps. 330-10.8 = 319.2. So you r are right there. My guess is the "high" brace height you have accounts for the 6fps difference in your measurements and the advertised speed. I have not really shot past 50 yds so I can't help you too much there.
trinitystrings412@gmail.com
WTBJR
Post by WTBJR »
xcaliber wrote:Sounds like you don't have the S5 on the bow by what you said about the brace height. I would set your brace height to 1", and give it another go! My next step would be to check the fletching on the bolts. I switched to blazer vanes just for the improved longer range accuracy, make sure that you have them set perfectly in line, they do tend to move in the jig slots a little. Post back after trying these please.
Good luck,
Dan
Dan, I have the stx dampener system. Not sure if i was clear on my brace height. I have it set where the string is just inside the line as the video says.
From where do i measure the 1" from?
My other question is, that since I chronoed all shots at 313 and my scope speed ring was set on 325+ andm my 50 shot was spot on. Do i need to adjust the speed ring to 313 and re-site the scope in??
I thought that the instructions said to adjust the 50yard pin with the speed ring, but the 50 yard shot was spot on, set at 325??
Thanks
Bill
awshucks
Post by awshucks »
I don't understand 3/16" above 'line closest to the shooter". I use 1 1/8" bheight [serving just touching the inside of the 'high' mark].
As has been explained, speed ring grads are for reference only.
W/ 8 kills you are among the 'experts' on here! :mrgreen:
nchunterkw
WTBJR
Post by WTBJR »
awshucks wrote:I don't understand 3/16" above 'line closest to the shooter". I use 1 1/8" bheight [serving just touching the inside of the 'high' mark].
I was having a hard time writing where my BH was. It is, as you say, the serving is just short of touching the "high" line
