Broadhead question on capatability
Old Mountain Man
Post by Old Mountain Man »
I have been informed that traditional archery broad heads and crossbow broad heads are manufactured to different standards due to the quickness of crossbows and the harder hitting of the crossbow.
Therefore a traditional broad head is not recommended for crossbow .Having said that , what about the circumference base , of the broad heads of the crossbow and the tradional archery .I ask this , for I wanted to use a Bolt Cutter broad head on a traditional arrow ( Aluminum 2117 shaft.), for a friend of mine.
Will this work for hunting?
Thanks
OMM
Re: Broadhead question on capatability
Yup, fer a very long time 2117 were Excals go to arrows.
Excal1
Post by Excal1 »
What are you considering a traditional head? Many and probably most use a head that was originally designed for a regular compound or recurve style bow. Some companies have come out with "special" heads for crossbows, but more times than not, it is marketing. Some like to use Snuffers and Magnus with crossbows, they are very traditional heads.
*** Matrix 405
*** Matrix 380
Hawke XB30
Hawke XB30 Pro
xcaliber strings
Boo strings
BE Executioner & Zombie
I can't believe that cop put me in the back seat when I clearly called shotgun.
Limbs and Sticks
Post by Limbs and Sticks »
Excal1 wrote:What are you considering a traditional head? Many and probably most use a head that was originally designed for a regular compound or recurve style bow. Some companies have come out with "special" heads for crossbows, but more times than not, it is marketing. Some like to use Snuffers and Magnus with crossbows, they are very traditional heads.
The magnus stingers 2 blade and ss snuffers along with the G5's are my first choice with any x=bow made
Wes
"Maxine"
1.75x5 Burris scope
STS
Feathered easton 2020's
Magnus stingers
