using easton xx75- 2117's
DaveShooter
Post by DaveShooter »
I have some old 2117's from recurve days. So I cut 'em down and made some 20" bolts out of'em. I thot I read in past subject matters here on the forum guys had used them and shot them in their Excal-x-bows. I normally use 2219 shafts but did this just for giggles. I know the min arrow weight is 350 min grain weight. Don't have a grain scale anymore so is it okay or not to use this size shafts without harming the bow limbs. I did try one for the heck of it. Just didn't want to shoot anymore til I heard yea or nay-Thanks :D
Re: using easton xx75- 2117's
That used to be the main arrow size from Excal. Very good to use
DaveShooter
vixenmaster wrote:That used to be the main arrow size from Excal. Very good to use
Thanks for the input-dave :D
Tom
Post by Tom »
Easton used the 2117 arrows as the main supply sizes. Excalibur and others used these as the main arrows they sold. For some unknown reason, Easton changed the 2117 to 2216. The 2216 (22/64" dia) was 1/64th larger in diameter, but only 16 one thousands wall thickness which was one thousands thinner then the 2117 arrow. But all in all, the arrow weights between the two were equal.
I still shoot both arrows.
Tom
Limbs and Sticks
Post by Limbs and Sticks »
It may be that arrow size has took more game than all the rest combined, just a guess
Wes
"Maxine"
1.75x5 Burris scope
STS
Feathered easton 2020's
Magnus stingers
Drew
Post by Drew »
If I recall my engineering classes correctly you will gain more stiffness (spine) from a diameter increase than a wall stock increase. So a 2216 will be stiffer than a 2117.
Drew
2013 Matrix 355 Xtra
TT Single Stage
Boo & Xcalibur flemish strings
18" BE Zombie Slayers
VPA 3-blade broadheads
Farmer
Post by Farmer »
I still have both sizes , they shoot to the same poi .
Raymond
Post by Raymond »
Folks, I have some Easton XX75's and XX78's , 2213's are they strong enough to be shot with an Equinox? Or would they be best shot with a lower poundage crossbows such as the Vixen II and the Phoenix?
Thank you,
Raymond
Limbs and Sticks
Raymond wrote:Folks, I have some Easton XX75's and XX78's , 2213's are they strong enough to be shot with an Equinox? Or would they be best shot with a lower poundage crossbows such as the Vixen II and the Phoenix?
Thank you,
Raymond
Raymond I use 2213's a lot, use them with confidence.
Wes
"Maxine"
1.75x5 Burris scope
STS
Magnus stingers
Raymond
Post by Raymond »
Thank you,
Raymond
Wes
Thanks for the info Wes. I will cut down some inserts to make nocks and chamfer them and weigh and get them the same weight and I will be all set then.
Thanks,
Raymond
the elf
Post by the elf »
I have XX75 at 20 inches and they weigh 330.2 grains with 5 inch vanes and no arrowhead.
I also have some 2216 at 20 inches and they weigh 336.4 grains with 5 inch vanes and no arrowhead.
I also have some of BIG JOHN'S 2216 at 20 inches with 2 inch blazers and wraps with brass inserts and they weigh 393.5 grains with no arrowhead.
I usually shoot 125 to 160 grain broadheads.
2117 has been my main arrow of choice for many years.
bob1961
Post by bob1961 »
I have been shooting 2117's since I got my exocet 200 in 08, my arrows weigh in at 550 gr and I have had no problems with them being weak in spine :wink: ....
exocet 200. STS dampers.
boo string and trigger work.
munch mount quiver mount.
125 gr slick trick magums.
2" blazers on 2117 XX75 w/ brass inserts.
Spike Country
Post by Spike Country »
Do you guys just put another insert in for the nock? Is there a plastic nock that will fit? I got allot of 2117 and like the idea of cutting them down.
MICHIGAN MEAT HUNTER "Shooting Tomorrows Trophies Today"
Proud member of the Michigan Crossbow Federation!
Limbs and Sticks
Spike Country wrote:Do you guys just put another insert in for the nock? Is there a plastic nock that will fit? I got allot of 2117 and like the idea of cutting them down.
E-bay has the plastic nocks for the 21 and 22 series alum arrows these are what I use with no problems.
Wes
"Maxine"
1.75x5 Burris scope
STS
Magnus stingers
the elf
Post by the elf »
Usually I use the same inserts front and back----and it has worked for me.
