how heavy a point can i use on the diablo bolts??? is there a manufacture limit?
shooting a matrix 380 5 minutes old, wow it is fast, now to try and start trying to quite it down a bit.
diablo point weight
LongCarbine
Re: diablo point weight
You can shoot 100 grain tips and up . The arrow with out a tip is 250 grains. The best way to quite it down is a Boo string with cat whiskers. Heavy arrows also help. But the deer won't mind the noise
Axiom (Alum.Rail)
Matrix B.D 330
Axiom (Alum.Rail)
Matrix B.D 330
No top end on the weight that I'm aware of. A number of folks using 150 or 175 grain slicks on the Diablos. You'll forget about the noise, once a deer is on the ground...lol! Make sure to have your string a string width or 2 off the REDs. X2 on the Boo string and heavy arrows really help a bit too.
Welcome to the forum too!
steve rodo
I shoot 150 Gr. BoltCutter's .Though i like my Shaft's Heavy.
The Heavier you go ,You will lose some Speed.Im more into Accuracy then Speed.
Shalom!!
Shalom!!
2013 380 excalibur X 2 BEE arra's 465gr loaded out arra . HHA Optizimer Lumenocks Red 150gr boltcutters Trigger Teck 1.5lb Dan's Custom String C2 Crank .24% FOC 105KE
A True Friend Never Lie's.
