Got a Matrix 380 and it didn't like my Thunder Head 100's . so i bought some Rage Crossbow 100's and they shoot dead on. I have never used these heads I was just wondering If anyone uses them and how they work on deer ....
Re: Rage Broadheads
Never had the chance to tell. The Rage open in my quiver as I walk, so when it comes time to hunt all I see is dysfunctional blades where broadheads once sat.
- Peacemaker
Re: Rage Broadheads
I put a protective dental rubber band on them so they don't open in flight. they fly like field points. Shot two doe in the past month. Perfect shots, 36 yards in one case and 39 yards in the next (exocet 200); both pass-throughs. The first deer went 20 yards before expiring. The second deer went about 20 feet.
So....aside from the price....I like them.
Re: Rage Broadheads
They are good if they open properly. I have had them fail though. My brother lost a turkey and i lost a doe. That was enough for both of us to go back to fixed blade broadheads. I have no complaints about flight, they do shoot like field pts, but its the deployment you have to worry about. My thoughts i have never had a fixed blade broadhead fail me and shot opportunities are too few and far between to not trust your broadhead to do the job. Just my two cents worth.
Don't put off till tomorrow what you can do today!
Re: Rage Broadheads
THe last 2 deer I have shot have been with the Rage Crossbow 125 grain. Alls I can say is WOW!!!!! Best blood trails I have ever had they were devastating...
Re: Rage Broadheads
New ones have a collar.They open just fine out of my matrix!
- one shot scott
Re: Rage Broadheads
Pydpiper wrote:Never had the chance to tell. The Rage open in my quiver as I walk, so when it comes time to hunt all I see is dysfunctional blades where broadheads once sat.
Re: Rage Broadheads
In my situation I didn't pay, sorta.. I got them as part of a trade.
I put the second band on a couple yesterday, they may just be a bit too snug now, time will tell.
For the last year I have been using the Rage X-treme, it is the one with the plastic collar, it is a way better approach than the bands, bigger cut and they look downright sexy..
The second band was no easy task, getting the band over the first cutting blade cost me a few bands, little buggers fly off to nowhere land, in a hurry.
Rage is one of those things that are either hated or loved, I have a few so I will give them a go..
- Carnivorous
Re: Rage Broadheads
I have 2 rage xbox heads left. Once again the buck I shot on Monday resulted in another lost arrow.
I am making the switch to nap spitfires when I use these last two rage heads. I am impressed with the spitfire design and they have a great reliable track record. The nap and rage practise heads shoot exactly the same out of my 355 so the transition will be easy.
Re: Rage Broadheads
i'm on the fence with mechanicals.. i missed one at 20 yds and i think it opened early. I'll stick to fixed blades.
Re: Rage Broadheads
They work fine as long as you make a good shot.
They are designed a little bad in various ways. I whacked a few deer with them before discovering their weaknesses. I don't use them anymore.
Mike
Excalibur Matrix 355
Re: Rage Broadheads
If your using the new crossbow heads with a collar make sure you position the collar so the tabs at the bottom of the blades are tucked inside and you won't have a problem.
- nchunterkw
Re: Rage Broadheads
Shot a few deer with them. Two opened early. I got lucky on one and unlucky on the other. Fixed from now on. As was said earlier shot opportunities are too few to waste. Also, on the ones I did recover, the blades were trashed. Too much $$ for a "disposable" head for me.
trinitystrings412@gmail.com
Re: Rage Broadheads
I never liked the 2 blade Rages because its still a slice instead of a 3rd or 4th blade cutting through flesh and bone. I've killed 13 deer with the Rages I think 12 have been with the 3 blade Rages. I switched to the Slick Tricks last year because I got tired of trying to change the blades out of the Rages with not much luck it started getting pricey since I try and kill about 3 to 4 deer with bow and xbow. The 3 blade Rages even though they're 1 1/2 cut a bigger hole than that and the blood trails are very good if you're shot is in the boiler room. I always used dental bands and never hand any premature openings with the 3 blades. Good luck with your decision.
Stryker Katana 360
Black Eagle Zombie Slayers
