Bow Leveling / Level Installation
8ptbuk
Post by 8ptbuk »
I may be wrong about these Matrix bows but they seem more sensitive concerning POI when canting sideways than the Magtip bows did . Maybe the Speed ( 380 ) or the shorter length is involved . Anyway I thought I might install a level of some sort on the left side of the riser so I could get a quick reference before the shot . Any suggestions on a level ? Thanks
8ptbuk's Flemish Strings
8ptcustomstrings@gmail.com
Re: Bow Leveling / Level Installation
You can get a fancy one from Excalibur or one of these.
http://www.lancasterarchery.com/cir-cut ... level.html
Excalibur sells them, but for some reason does not show it in their catalog.
The Matrix is not worse. The error is a function of the vertical plane being off, not the horizontal plane.
884savage
Post by 884savage »
I intentionally canted my 380 the other night about 45 degrees in each direction at 30 yards. I could see no change whatsoever in POI. I was surprised. Not sure what the other post means about a vertical canting issue??? The scope?
8ptbuk
Post by 8ptbuk »
Thanks Boo , I'll look into them and see what I think .
Horizontal Hunter
Post by Horizontal Hunter »
I used scope mounted anti-cant level for years on my Varizone. When I switched to a Hawke scope this year there is no room for a scope mounted level and I miss it. I am still trying to decide how I want to mount a new level.
This is what I used:
http://www.amazon.com/ACD-Anti-CANT-Dev ... =Anti-cant
Bob
Carphunter
Post by Carphunter »
when leveling a scope vs the crossbow... would leveling the bow by placing a level on the string get the bow itself correctly leveled...or would there be something i'm missing there on that?
I prefer to put the level on the deck of the main frame.
91redford
Post by 91redford »
I read on the forum that someone used a string/line level and used a razor knife to trim off the excess plastic and two sided tape to stick it on the xbow, this i did and mounted it were i can see it with my left eye while my right eye is lined up with the scope. the part that gets the scope aligned to the bow i did by hanging a weighted line and setting the bow up perfectly level and sighting through the scope comparing the scopes vertical line to the hanging string. rf
Post by paulaboutform »
Boo wrote:I prefer to put the level on the deck of the main frame.
X2- I like the Excalibur bubble or the cir-cut bubble. I've got mine on the left side of the deck as I'm a righty. Simple stick on, easy, quick acquisition and no problems after thousands of arrows.
gspeakes
Post by gspeakes »
Put a Vortex scope bubble level on my scope. Works great.
M310 "Valkyrie"
Hawke 1.5-5 x 32 Ir Sr Crossbow scope
Ramcat 100gr, Rage xbow 125 gr
Nap Spitfire 125 crossbow bh.
Submariner and Viet Nam vet
gspeakes@gmail.com
