broadheads
broadheads
my setup is muzzy 100s with my bolts weighing about 355 grains total which is about 5 grains over the min weight, want to increase my weight but i also like the muzzy 100 s and how they fly, anyone with a suggestion of how to increase weight of arrow. , might have to go tot a heavier broadhead
Re: broadheads
Did you mean 355 total grains? If you get the accuracy you demand, and you have the K.E. which you should with any model, no need to change. If you want to increase the weight, the easiest way would be heavier BH's.
Good Luck this fall!
Re: broadheads
Do you have brass inserts up front?
Re: broadheads
no insert installed yet and i did mean 355 grains, im told by the bow shop guy that i cant go any lower than 350 as it would almost be like a dry fire, i have been shooting muzzy 100 on my compound and on old exocet and they flew great but havent shot new matrix yet, hopein the fly great. from whatim learning the heavier the better, not knowing lots about bolts would i be better to leave my bolts at 20 inches or cut them down to 18 and put a heavier insert,
Re: broadheads
Using the 330 matrix its draw weight is 220 lbs
