The stock rings aren't tall enough for the nikon, so I ordered new rings....they came, but apparently there is a size issue.... (very new to this scope thing)
Need a little insight here.
thanks!
what size rings do I need for my micro??
- bikerbob24
Re: what size rings do I need for my micro??
medium height is what I used on mine....
Micro 335
Nightmare 335
Matrix 330
Axiom
Vixenmaster Flemish Strings
K-9 handler and trainer , K-9 Baily my partner for 7 years, we are now retired , spending our time hunting & fishing or just enjoying life.
Nightmare 335
Matrix 330
Axiom
I'm in the exact same boat and I'm buying medium rings this weekend.
Micro_335 - Nikon Bolt XR - 15.5'' Zombies - Killzone 100GR
Matrix G340 - Nikon Bolt XR - Muzzy 100GR
- Deerstalker
The Nikon Bolt Xr has a 1" tube and I used Weaver Medium Tactical rings to mount the scope on my Equinox.
Semper Fi
2012 Equinox
2012 Axiom SMF w/S5 (son # 2)
2012 Equinox
That's exactly what I'm looking for....
and the width of the rail?
I guess I could measure, but don't have the bow with me at the moment.
Thanks
Thanks
- Deerstalker
http://www.brownells.com/.aspx/lid=1072 ... Difference_
Check out this site for info on the scope rail.
Semper Fi
2012 Equinox
2012 Equinox
If it was just slightly off I would file down the base to fit to maintain the lowest scope mounting possible.
Mag Air
Sig Sauer Romeo 5
Excalibur Quills
Tooth of the Arrow broadheads
Vixenmaster strings
Sig Sauer Romeo 5
Excalibur Quills
Vixenmaster strings
This is right..you can file down the front tabs on your scope mount..I almost did it to mine as I wanted my scope as low as possible but not wanting to start cutting I ordered some weave 1" medium mounts from ebay. while they aren't fancy mounts they are comparable to the factory ones ..I think were less than 6 bucks shipped..canoe13 wrote:If it was just slightly off I would file down the base to fit to maintain the lowest scope mounting possible.
- Deerstalker
I had to file another slot into my non-ADF scope mount rail to enable my preferred eye relief per talking with Dan & Boo. My rail came with 5 slots and now it has 6.
http://www.excaliburcrossbow.com/catalo ... _and_rings
Semper Fi
2012 Equinox
2012 Equinox
I got the Red Hots, 1" medium height from Cabelas, $20, and solid as an anvil!
[URL=http://s1339.photobucket.com/user/xcali ... d.jpg.html]
I just installed the Nikon using the Millett mediums, 14$ fits like a glove with very little clearance just how I like it!
