1. Horton Archery Crossbow Rail Lube ST091; 1 oz - $3.99 shipped
2. Dead Down Wind Crossbow Rail Lube / Wax (Pack of 3; .15 oz each) - $9.99 shipped (this actually says it can be used on the string and rail)
3. Rail Snot Crossbow Rail Lubricant 1 Oz Tube - $9.95 shipped
4. X-FUEL 325+ High Performance Rail Lube Fluid 1 oz - $11.99 shipped
5. Excalibur Ex-Lube Rail Lubricant 7005 - $13.21 shipped
Does anyone have any experience with these? For convenience factor it would be nice to be able to use the "Dead Down Wind" for both the string and rail lube as it says. At the same time I want to make sure I use whatever will reduce wear on the rail/string the most and hopefully maximize FPS... yeah I know it might now be more than 1 or 2 FPS, but every little bit helps
Just looking for some opinions and feedback.
Oh not sure if it matters, but keep in mind, I have the polymer (plastic) framed Grizzly.
