Aligning Broadheads with Fletchings
Just got a half dozen Zombies with 92 gr. brass inserts. All fletching is the same color (no cock feather.) My broadheads do not line up at the desired 3 o'clock/9 o'clock position on any of them. Thinking about removing the inserts and spinning them to the correct position. Can I soak them in acetone and pull them out? Don't really want to use heat and ruin them. If so, what glue to put 'em back in? In the old days, I used hot melt sticks on woodies and aluminum, and still have a couple. Good choice for carbon/brass attachment?
Re: Aligning Broadheads with Fletchings
Never soak carbon shafts in acetone it can greatly weaken the shafts as it can affect the glue that holds the carbon fibers together.
Secondly, it has been proven over and over that alignment of the broadhead has no impact on broadhead performance. So don't sweat it. The bigger issues are if the spine of your arrows is aligned, heads that spin true and if you have proper FOC. Which with 92gr inserts sounds like you have covered.
A society grows great when old men plant trees in whose shade they shall never sit.
I try to match broadhead blades to vanes, too, (doing so while making the arrows and bolts to begin with). But honestly, when using quality components with a tuned bow, I never saw a benefit from achieving it, other than it looking cool and playing with my mind.
I've shot fixed blade heads, 150 grain Magnus Stingers, out of multiple Excalibur bows and with the blades positioned every which way in relation to the blazer vanes and they all group the same, an inch high. Same goes for 100 grain Dead Ringer Rampage heads (which actually group better than field tips because the blades help spin the arrow) and Grim Reaper heads with my compound bow. And the same goes for the Magnus Stinger heads cited above with my recurve.
Try shooting your heads as they are now. I bet you find you don't need to index the blades to vanes.
- Location: 35 mins North of Lake Erie and 35 mins East of Lake Huron
As other have said I'd not worry about that so much with Zombie shafts. If you have any that don't group well set them aside. Then number the vanes on those shafts ABC or 123 and try using each vane as the cocking vane to see if that brings them into line with others - this fixes most issues. The zombies being the stiffest arrows out there have very little spine issues so they can fletch wherever without putting cock feather on spine.
- nchunterkw
Hunt it wrote:As other have said I'd not worry about that so much with Zombie shafts. If you have any that don't group well set them aside. Then number the vanes on those shafts ABC or 123 and try using each vane as the cocking vane to see if that brings them into line with others - this fixes most issues. The zombies being the stiffest arrows out there have very little spine issues so they can fletch wherever without putting cock feather on spine.
This right here.....
[email protected]
[email protected]
I actually soak my fletch end of the shafts in a glass jar of acetone to clean off the residual fletching left on the shafts when I'm replacing my vanes. I also dunk my freshly cut and squared shafts in acetone before epoxying my inserts in to clean the residual carbon out. I have found no adverse effects or signs of the shafts breaking down. This is shooting arrows out of a M405, M380, and M405+++ custom.Fullquiver wrote:Never soak carbon shafts in acetone it can greatly weaken the shafts as it can affect the glue that holds the carbon fibers together.
Thanks everybody. Great advice here. That's what I like about the Excal Forum!
