[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result Newest stock in the stable. - Excalibur Crossbow Forum
Exomag ,Exocet,Micro 335
Scorpyd Ventilator
Gold tip laser bolts, Zombie Slayers,Spynal Tapp
Slick Trick, Rage, Magnus bullhead
Danny Miller Strings
Shoot a big one, Let the grunts walk
Beautiful stock Mark. Can a person buy a Excalibur Xbow without the stock, like the rail, trigger system, limbs, etc. but without the hardwoods stock? Or would I have to buy the complete outfit, only to take the factory stock off and leave it sit?
Grey owl , real simple , pop two bolts out wiggle the composit stock off and slide the wood on, install the bolts and your good to go.
Mark
Scorpyd Ventilator
Mark, are those stocks pre-inletted or did you do them from scratch? Both really nice. I've stocked quite a few shotguns and several rifles over the years and I've found that once I put a AAA fancy piece of walnut on a shotgun, it doesn't get hunted much after that. I just can't see taking a beautiful piece of wood in the timber and scratching it up. Do you plan on hunting with these bows?
Gary , i make these all from scratch. Yes i do use them, it would be a terrible waste to have something that beautiful and not use it. That would be Sorta like dating Miss America but not taking her out on the town cause your afraid someone would look at her
Not only do i plan on hunting with them they have proven themselvs on the range and in the field!!!! They dont just look good they preform and are tough too!!!!
Mark
Scorpyd Ventilator
