Does anyone make an actual insert that allows for different weights to be screwed in??
I know there are some external weights that can be screwed in, but the weight choices are limited AND it requires the weight to be on the outside and squared up to both arrow and point.
For example, the "base" insert" would be a threaded "sleeve" that fits into the arrow shaft and is permanently glued in, just like any insert is right now.
Then there are different weight "inner" inserts that screw in and allow your point to screw into them.
That way you could play with different insert weights until you find what works for your set up without having to make them permanent.
(Did I just give away my "million dollar" idea???
