Crossbow bolt repairs : life hack
vpsaline
Post by vpsaline »
You can improvise a rear nock for a crossbow bolt out of a .22 Magnum cartridge casing (it has a flat base and it's made from brass)!
Micro_335 - Nikon Bolt XR - 15.5'' Zombies - Killzone 100GR
Matrix G340 - Nikon Bolt XR - Muzzy 100GR
Re: Crossbow bolt repairs : life hack
The ID of a typical quill or Bee is .3015 and .300 respectively. And the OD of a 22mag case is .242. base is .29something. Not sure about a fired case.
But either way, it ain't gonna stay where you put it
I just tried this on some Excal firebolts and some 2219 alum shafts and the .22 Mag caseing is to small it slides into the shaft.
foofoo
Post by foofoo »
i would try the plastic bag trick or some hot glue if your in real need to make it work.also i would be concerned of the weight of the all brass 22 mag case.
Arrowflinger
Post by Arrowflinger »
Gimme that arra with the 22 nock; here , someone hold my beer.
