what gen micro?
bobcat
what gen micro?
Post by bobcat »
Could someone explain the different "gen" micros? i bought mine new 3 years ago but dont know which i have. i think someone helped me figure it out once on here before but i cant fine the post. aslo why are there 3 generations of them and which is the best?
Rambeaux
Re: what gen micro?
Post by Rambeaux »
Gen 1 on bottom, gen 2 on top. I haven't heard of a 3rd gen. Supposedly the gen 2 has a differnt angle.
However, I have a Micro 355, gen 2, and still had a limb fail. On the bright side, Excalibur's CS is the best in the industry,
or any industry for that matter (IMO).
Micro 355/XV530IR scope/8pt flemish/DB Killers and bumpers/Slick Trick 150's/16.5" Zombie's
Re: what gen micro?
Its quite a significant change in the angle. You can see how far back it really is when you put a gen 2 riser on a gen 1 rail. It moves the brace height back quite a ways. Id measure it, but its downstairs and im not .
Possitives and negative about both. More possitive than negative in either case.
bobcat
Re: what gen micro?
Post by bobcat »
i cant really tell from the pic because one bow is cocked and one is not. or am i looking at the wrong thing
Re: what gen micro?
See the curve, look where the arrow sets, that should make it very to see the difference.
Rambeaux
Re: what gen micro?
Post by Rambeaux »
bobcat wrote:
Fri Dec 29, 2017 7:24 pm
First Gen:
Second Gen:
Re: what gen micro?
Last pic. Gen.2
Re: what gen micro?
Look at the shape of the riser itself, one has a webbing(gen1) and the other has a big open hole(gen 2)
Gen two has a more swept back angle, which offers less strain on the limbs. But it is also inherently, "weaker" when comparing the amount of energy it allows the limbs to create and hold. So therefore the second gen of micros have a longer mainframe to keep the speed as advertised. There are two ways to make power, angle the limbs forward, or increase the draw length.
One is not better than the other, just a different way of acheiving very similar results.
Tlyle
Re: what gen micro?
Post by Tlyle »
All this Micro info is helpful. Thank you.
One additional question. I have a new Micro 355. However, when you look at the bow, the only identity is Excalibur on one side, and Micro on the other. How do you identify the difference between the Micro models, 335, 355, etc...?
Matrix 380, Zombie Slayers, TT 2.5
Matrix 360 Bulldog Blackout, TT 1.5
Shoot Straight, Eat Steak!
W.Miguire
Re: what gen micro?
Post by W.Miguire »
the rail on the 335 will be shorter than the 355.
W.M.
Re: what gen micro?
Tlyle wrote:
Fri Dec 29, 2017 10:30 pm
355, is either black or camo in the case of the suppressor.
As Bill stated, the length varies by 1/2" for each model. The 315 is a full 1" less, and thw 335 gen2 is 1/2" less than the 355.
335 gen1, has the same length rail as the 315(a gen2)
Altho, it also important to mention that outside of the internet crossbow world the "gen" identification doesnt exist. Its simply old sryle and new style from excal.
Re: what gen micro?
The third generation is like the second but the hole for the string stop is not drilled completely through the riser.
Rambeaux
Re: what gen micro?
Post by Rambeaux »
Sat Dec 30, 2017 12:33 am
In that case, I have a gen 3 riser. WOO WHOOO!
Re: what gen micro?
So your saying Gen 3 is heavier to tote around :wink:
bobcat
Re: what gen micro?
Post by bobcat »
janesy wrote:
Fri Dec 29, 2017 10:56 pm
so if i shim my riser on my 335 a 1/2 i have a 355? :shock:
