string tension
Cardinalsfanforever
string tension
Post by Cardinalsfanforever »
New to crossbows. 6 week old matrix 380. had to put 3 twists in string to get it off the reds approx. 1/4". Do they stretch that much? How much overall stretch should I expect?
bigbowman
Re: string tension
Post by bigbowman »
The strings do stretch. I only use custom Flemish strings and they only take about 30 shots to stretch them out. Good luck!
Cardinalsfanforever
Re: string tension
thanks
Buck
Re: string tension
Post by Buck »
Some on this site have suggested to leave the bow cocked over night after putting on a new string. I have done it and it helps get the stretch out quicker.
Micro 335 / Hawke XB30 Pro- Excal Sound Deadening System....
Matrix 350 SE / Hawke XB30 Compact - Couldn't say no......
308 Shorty / Hawke XB30 Pro- Tack driver ....
Axe 340 Raid / Hawke XB30 Compact - ....
Cardinalsfanforever
Re: string tension
thanks
Re: string tension
Nothing gets the string creep out faster than shooting. Alternatively you could easily build a jig (see my website) and put it under tension, wax it and get it hot by rubbing with your fingers and leaving it until it cools down.
When shooting a new string in, keep your brace height a couple of string widths or more above your desired mark. That will speed things up.
