Matrix 355/360
Matrix 355/360
Could someone tell me the difference between the Matrix 355 and the Matrix 355/360 "Lite Stuff", I see on eBay. Did they use old parts from other Matrixes and come up with another Special Edition?
Re: Matrix 355/360
The Matrix 360 is an exclusive build for American Archery. You can see it here: http://www.excaliburcrossbow.com/exclusive-excalibur-crossbows/
I once asked them why the auction said 355/360, they told me it was to increase hits from search results because the 360 was a goofy number.
My guess is that it has the swept back riser instead of the Matrix forward riser, so it needed a longer rail to maintain speed.
The Matrix 355 specs:
Speed: 355 fps.
Power stroke: 12.2".
Draw weight: 240 lbs.
Length: 34.8".
Weight: 5.4 lbs.; with accessories: 8.4 lbs.
The Matrix 360 specs:
Speed: 360 f.p.s.
Draw Weight: 250 lbs
Power Stroke: 13.9"
Overall Length: 36.5"
Weight: 6.2 lbs
Speed: 355 fps.
Length: 34.8".
Speed: 360 f.p.s.
Power Stroke: 13.9"
Weight: 6.2 lbs
Micro Suppressor 400 TD (Two of 'em)
Bulldog 360 Blackout
Micro 360 TD Pro (Kryptek Altitude)
Matrix 380
Vixenmaster strings - Love 'em! | DrStirrup - Good stuff man!
Matrix 380
