![Deadhorse :eusa-deadhorse:](./images/smilies/eusa/deadhorse.gif)
CR 2032 battery drain in X bow scopes.
Has anyone had issues with 2032 batters draining even when your scope is turned off? I even put it in backwards and barely screwed the cap on and it still drained. All in less than a month.
Excalibur Matrix Bulldog 380 with Excalibur Twilight DLX Scope
Diablo Bolts, Excalibur Boltcutter 150 grain.
Re: CR 2032 battery drain in X bow scopes.
No never had that problem. Must of been a bad bunch of batteries?
Nope. Two years on one battery and still going strong. Try a different retailer for a battery. If it still drains fast, send it back for warranty.
Hank
Hank
Agree, either the battery was defective or the scope is. I have several types of scopes that use them, and never had a battery that lasted less than a month, usually they last years as already stated.
I only turn the lighted reticle on when needed on the scopes, by keeping it on all the time while hunting and then turning it off would drastically reduce battery life.
I report long life with Duracell and Energizer 2032's.
I have a 6 year old Hawke scope and it still runs fine with the original CR2032. I don't ever use the light and took it out of my other scope so I wouldn't forget about it and have it leak and ruin the scope. Never found the lighted reticle useful for deer during legal shooting hours, maybe for black animals like bear or boar it would be important...
- IronNoggin
Use the lighted reticles all the time. Prefer the blue over the red, on low settings.
Have provided many a fine buck and bear.
I swap out the batteries each fall. Likely not necessary, but something I do.
Had one on an older bow that lasted 3 years.
And I always carry a couple of spares.
As the others noted, you either had a bad batch of batteries, or the scope is pooched.
Try a new set and that should indicate which way to go...
Cheers,
Nog
Cheers,
Nog
I might add, that I secure a spare battery in a 1" x 1" mini zip lock then tape it using a small piece of black Duct Tape to the non cheek side of my stock, in case it is needed in the field.
Simply called preparedness.
A few months ago I left the illumination on for a full day on my new scope by accident. When I got it out to shoot the next day I noticed it was still illuminated. I'm not sure how long the battery will last, but mine has been illuminated for at least 26 hours and is still kicking. I'll probably put in a new battery before the season, but it is good to know that if I leave it on it won't be dead in a few hours.
Recovering Excalaholic![Laughing :lol:](./images/smilies/icon_lol.gif)
I have never had an issue with any bein drained
Nor have I.
When I used Hawke scopes, and still use the TR530IL on a B/U cbow, I found illumination virtually worthless as they were too bright in low light conditions.
Only when I eventually used higher level scopes starting with WCE scopes, then L VXR, and eventually Zeiss Duralyts, I found the true advantages of lighted reticles. When the dot can be dimmed to where it’s barely perceptible, it can become invaluable right at dark. And, “right at dark” is a special time!
- nchunterkw
SEW which Hawkes? I find the SR-Pro with infinite adjustment just right at dusk when I turn it on to the minimum possible setting.SEW wrote: ↑Mon Jul 01, 2019 8:48 amNor have I.
[email protected]
[email protected]
- IronNoggin
The Hawke XB 30 Compact I run has excellent lighting for my eyes.
On the lowest or second lowest setting (again, prefer the BLUE) it is pretty much perfect - for me.
And as noted, has been the regret of many a buck & boar.
Higher settings, not so much.
Cheers,
Nog
Cheers,
Nog
- nchunterkw
I wish the SR Pro had 2 colors. Red is the only option, but I like it for black pigs, and black bears at any time of day, and then at low light too. The old XB1 I had had RED/GREEN but wasn't infinitely adjustable . I like the adjust-ability on the Pro far better.IronNoggin wrote: ↑Mon Jul 01, 2019 3:22 pmThe Hawke XB 30 Compact I run has excellent lighting for my eyes.
Cheers,
Nog
It's getting to be that time isn't it?
[email protected]
[email protected]
You have a good question. SR Pro. I’m spoiled by my ( used) Zeiss Duralyts and even the Leupold VXRs. I varmint hunt till black. I want that tiny speck of a glow.nchunterkw wrote: ↑Mon Jul 01, 2019 10:23 amSEW which Hawkes? I find the SR-Pro with infinite adjustment just right at dusk when I turn it on to the minimum possible setting.SEW wrote: ↑Mon Jul 01, 2019 8:48 amNor have I.
