Does the new axe and TD shows use matrix limbs?
Big45
Post by Big45 »
Just a question about compatibility for my BD 380. Does Excalibur’s use the same limbs as the matrix lineup?
Species8472
Re: Does the new axe and TD shows use matrix limbs?
Post by Species8472 »
The Axe and 360 TD are micro based. The 420 TD is i believe based on the Matrix.
Post by amythntr »
..... that is correct!
Anthony :)
Not entirely the same, the 420Td(and 440) use thicker limbs than the BD380 and BD400.
They are interchangable as long as you have the black ferrules. So depending on your year of 380/400 they may not fit without different parts.
Same for the axe. The new limbs are thicker at the strap and require the black ferrules.
New CRTGen2 limbs on the right. I lost my pic of the 440 limbs somehow unfortunately.
Post by amythntr »
janesy wrote:
Sat Oct 05, 2019 6:58 pm
.... that is correct also.... they use the more beefed up limbs.,. Thicker as you move toward the riser.... same is true for the A360.👍
Anthony :)
Bare in mind guys that there are oodles of hunters that have never had a problem with the old limbs and the lower poundage bows are much easier on limbs. I had a couple of sets go on my 315 until I figured out that my unpolished anodized riser was chewing away at the limbs. :roll:
Sat Oct 05, 2019 7:33 pm
Absolutely! I'm running what appears to be first gen blem limbs on the Axe and so far no issues. And they have a pretty good chunk out if them too
Lewism
Post by Lewism »
What the new 340 micro axe have 2 limbs already? How you tell on kryptec raid model ?
My First Bow excalibur 340 micro AXE kryptec.
Lewism wrote:
Sun Oct 06, 2019 10:19 am
No, that pic is showing the new limbs, which you have, beside the limbs from years gone by.
Stepnoutnb
Post by Stepnoutnb »
janesy wrote:
Sat Oct 05, 2019 7:37 pm
Janesy, what are you saying? You have the NEW axe model and you have put blem limbs on it that have a chunk out of them? Where are the original limbs? I'm not picking up what your putting down, I'm not smelling what you're cooking? :?
Wayne
Stepnoutnb wrote:
Tue Oct 08, 2019 7:37 pm
Wayne
I put black blemish limbs(with a chunk missing from them) on it. Just for fun. The original limbs are zip tied together on top of my gun safe in the basement with all the others.
Stepnoutnb
janesy wrote:
Tue Oct 08, 2019 9:40 pm
Wayne
I was a little confused.
Cheers
Stepnoutnb wrote:
Tue Oct 08, 2019 9:58 pm
Wayne
Cheers
I was just commenting on how resilient these limbs are 99% of the time. Now that I've posted they will probably blow up
Post by robertyb »
Wayne
I have never heard of Excalibur selling a blem limb with a chuck missing to anyone. Did you knock a chunk off them?
I'll clarify. Chunk was the wrong word to use. It's a void where the fiberglass didn't fill the mould. My point in even mentioning it was the fact that these limbs are so much more than resilient than they get credit for. They get all kinds of attention when they break... But non when they dont.
This is the definition of a blemish, and it functions perfectly fine. No tiller or speed loss what so ever . :thumbup:
