Guys,
I was taking the limbs off and had the limb side up towards me. A small stainless steel nut fell down to the ground. Any ideas?
Thanks
Dave
420 TD Question
Re: 420 TD Question
I believe there is a nut between the riser and rail to adjust tension. But I don't have a 420 here currently to look over
Re: 420 TD Question
If you were removing the limbs, all you'd have to do is remove the string, then remove the 2 recoil bracket bolts and then the main limb bolts. There is no nut involved.
It might be a good idea to take a picture of what the bow looks like now, especially where the nut came from
Re: 420 TD Question
Boo,
I was removing the limb bolt and bracket bolts. I didn't touch anything else and don't know where it fell from. I don't know if it came from the internal portion of the bow. My 405 was easy to split open, I don't want to try doing so with this one. It looks more complicated.
Thanks
Dave
Thanks
Dave
Re: 420 TD Question
I can't imagine what could have come loose from just removing the limb and recoil bracket posts. On Monday, call Excalibur. I think Peter Balfour is the best to talk to and tell him what wrench size the nut is.
Re: 420 TD Question
Boo,
Thank you, I am going to call them tomorrow morning.
Dave
Dave
Re: 420 TD Question
Problem solved, it actually came from my Allen wrench. Backed off the end.
Thanks Janesy and Boo!
Dave
Dave
Re: 420 TD Question
Your Allen wrench has a nut on it? That's different!
Re: 420 TD Question
Ha glad you figured it out, time for a good set of Allen wrenches if you'll be working on your excal. That investment( $24) will pay you back every day
Re: 420 TD Question
My Allen wrench set has a bolt on each end that holds the different sizes in place once the nut goes on the opposite end of the bolt.
Dave
Dave
