will it fit??
- Robinsons Rebel
will it fit??
Going to be getting a Marlin 336 for my grandson soon and hoping to pair it with a Vortex 3-9x50 Crossfire 2 and a DNZ mount with high rings.Don't know if it will fit yet. Has anybody tried this or should I drop down to a 40 mm? I like the v brite reticle so if all else fails, I could put the 50mm and my gun and give him my old scope!
2016 Matrix Grizzly (Red Bud)
18¨ Diablo lumenok bolts
R.E.D.S
String by xcaliber
R.E.D.S
String by xcaliber
Re: will it fit??
Put another scope on it. His cheek weld will be too high. Those are brush guns anyway and the smaller compact the better. 2x7x32.
Re: will it fit??
Yep, unless you're going to be shooting out into fields, that's way more scope than is practical. I have 3x9x40 on my .44 magnum rifle, and never moved it from all the way down when hunting.bobcattrapper wrote: ↑Thu May 21, 2020 5:12 pmPut another scope on it. His cheek weld will be too high. Those are brush guns anyway and the smaller compact the better. 2x7x32.
- AJ01
Re: will it fit??
I'll say this...if you put a scope with a 50mm objective on a lever action, your asking to get smacked by the stock!
Your cheek weld is way off from where it needs to be. And the recoil generated by a 30.30 round from a lever can be quite a shock to a youngster.
Vortex, Nikon and a host of other manufacturers make some very good low profiles in either 1.5-4 or 2x7 configurations which in my humble opinion would better match that rifle.
And if you're just asking opinions, and you haven't purchased the rifle as of yet, I'd look into a Model 7 Remington in 7mm-08. Less recoil, better rifle, and as he progresses in his hunting career, you can put that combo to use in many situation from whitetail to antelope.
Once again, just my humble opinion!!
Andy
Andy
