Arrow length ?
Lucky-Dog
Arrow length ?
Post by Lucky-Dog »
Im going to order some 18" arrows.
My question is, can they be used with most all other Excalibur bows ?
Matrix Cub
Montec CS 100 grain
Re: Arrow length ?
Post by amythntr »
Lucky-Dog wrote:
Mon Nov 02, 2020 2:59 pm
.....You lucky-dog....those arra's can be used with most Excalibur's....some choose longer or shorter depending on the bow of choice!
Lucky-Dog
Re: Arrow length ?
Post by Lucky-Dog »
amythntr wrote:
Mon Nov 02, 2020 3:05 pm
Sounds great. I was looking at Excaliburs website at specs and noticed some bows with different arrow lengths like 16" or something like that, and was curious if it was unsafe to use the 18" or not.
As long as I can use the 18" on any of them, we are good to go. I dont keep up with the latest and greatest, so Im trying to be safe and sure.
Thanks
Matrix Cub
Montec CS 100 grain
Re: Arrow length ?
Just make sure that they aren’t short enough to allow your foot to be under the point of broadhead when you decoding. It may get exciting.
Lucky-Dog
Re: Arrow length ?
Post by Lucky-Dog »
Mon Nov 02, 2020 3:47 pm
Ouch ! - Lol
No doubt about that.
So Im thinking I should be pretty safe with 18" on most all the bows.
Thanks
Matrix Cub
Montec CS 100 grain
otisbrazwell
Re: Arrow length ?
Post by otisbrazwell »
when arrow sticks out past the thing you put your foot in to cock the bow it really makes for a bad day
in the deer woods..arrow should be were your foot would kick out so you would say gee i am a real stupid
puck i should of removed arrow before decocking ...every thing about the crossbow is to be taken serious
like a gun :eusa-violin:
Re: Arrow length ?
Their is only one proper arrow length for a X bow arrow in my opinion and that is the length that takes the broad head to the far edge of the foot stirrup but not past it , the reason is that during decoking if you ever forget to take the bolt off the rail you do not drive it through your foot.
You want the arrow long enough that you can NOT get your foot in the stirrup with the bow loaded to fire other wise if you go to decock and forget to take the bolt off the rail you could drive the arrow through your foot .
Re: Arrow length ?
I like the Broadhead about one inch inside the stirrup so I can hang my bow while in the stand. Safety First always!
grouse
Re: Arrow length ?
Post by grouse »
gerald strine wrote:
Tue Nov 03, 2020 2:42 am
Under this rule the older wide limbed bows would require arrows longer than the 20" projectiles that are specified with them. I know this is true because I drove a boltcutter attached to a 20" shaft, into my left foot years ago with my Axiom.
