Insert glue survey
Insert glue survey
I was curious of what you guys use for insert glue my go to has always been a clean bath with a q tip with a product called acrosol its just a degreaser used for automotive use and dow 2 part "slow epoxy " never had an issue unless I stuck a tree.
I sometimes use a hot melt stick it works well holding a graphite fishing rod tip on. Never really had a problem with that holding either ...but the melting part is a pia.
I'm curious about the gorilla glue seems so easy 🤔
OhioXBowhunter
Re: Insert glue survey
Post by OhioXBowhunter »
I’ve always used Bohning insert iron so far no problems. Whatever Black Eagle uses is good I’ve never had any problems with factory arrows and I know I’ve tried to get the inserts out of some of the Proflight’s I have and didn’t have any luck getting the inserts out so whatever Black Eagle uses will be my next purchase on insert glue.
400 Suppressor TD
Bulldog 440
Matrix 405
Black Eagle Zombies
Black Eagle Executioners
G5 Montecs / Mega meats
Gorilla glue blue top. New bottle every time.
I recently picked up some green top in smaller tubes to try, it's the same, just gel formula
I have used Majic patch hot melt , A rubber made for patching waders, boots ect for the last 40 years.
Heat to melting apply to nock, push in with a twist then let cool and scrape off the excess .
To remove heat in steam or boiling waster and pull out.
Krazy Glue. I've never had one come out. Of course, I've never been able to get one back out afterwards either. If you ever want to get them back out, this is NOT the product to use.
Deaf jeff
Post by Deaf jeff »
clean everything with acetone and then use gorilla or bluglue
IN GOD WE TRUST
Jeff
animals are killed, crops are harvested
matrix 330
100gr spitfire maxx
Boo strings
excaliber strings
Dagriz knife
Post by robertyb »
janesy wrote:
Sun Sep 26, 2021 8:54 pm
That has to get expensive. I have been using the same bottle of Gorilla Blue Top glue for several years now and have not had any inserts pull or vanes come loose.
robertyb wrote:
Mon Sep 27, 2021 12:38 pm
Glue is cheap I can afford a couple bucks the few times a year I make some arrows, and I almost always leave it on my dashboard, or forget to put the cap on.
I also have two young kids that break everything so I go through it pretty quickly
Cyanoacrylate looses it's "fast grab" characteristics very quickly, 1 month. It has a shelf life of 1 year unopened. And trust me when I say, it goes bad fast. That's why we retail it as a fast grab item.
I use JB Weld two part epoxy for inserts and AAE fast set gel for vanes. Seems to work great for me.
nchunter
Post by nchunter »
janesy wrote:
Mon Sep 27, 2021 12:47 pm
This is very true, and true to a lesser extent of epoxies as well. To extend their life, always store your adhesives in the refrigerator—if your wife will let you, that is.
JB weld when I roll some up
Post by amythntr »
….. I’ve used rubber glue which you heat up and roll the insert in and apply…. Impervious to temp changes…. “Ain’t lost me an insert since I started rolling me own arras for the last 8 years!”
I haven't lost an insert for 10 to 15 years since I learned that surface prep was more important the glue. Just about any glue will work well as long as you take the time to allow the glue to do its work. If any one remembers I came up with the idea of rolling the inserts between 2 axe files. Now I scuff them up with a red 3M pad. Works well!
lituani
Post by lituani »
AAE Max Impact (black), paired with Black Eagle aluminum flat nocks. I've shot those arrows dozens of time and almost always use the threaded T-handle to pull arrows. Never lost a nock yet (which happened twice on factory BEE 18"/.001 arrows).
lituani wrote:
Tue Sep 28, 2021 12:49 pm
You don’t have a Danny Miller Arra Puller? :shock:
