Rebolt quiver
mchurch
Rebolt quiver
Post by mchurch »
I like look of the rebolt quiver. It looks like it has only one arrow gripper. I wonder how well it does with mechanical broadheads
Excalibur Revx
Hawke Xb 30 pro
SWAT juggernaut broadhead
Re: Rebolt quiver
One would imagine that the marketing department would describe how this quiver holds arrows securely while apparently using just one rubber gripper. At the surface I have to say that I wouldn’t use a single gripper quiver for any broadhead!
nchunterkw
Re: Rebolt quiver
Post by nchunterkw »
How does this mount? Picatinny only?
[email protected]
vaXbow
Re: Rebolt quiver
Post by vaXbow »
Inside the hood is a rubberized insert with round holes for the tips. Works well. I hunted with the Micro 380 with zero issues concerning arrows not staying put.
The Horizontal Zone
[email protected]
mchurch
Re: Rebolt quiver
Post by mchurch »
What broadhead did you hunt with?
Excalibur Revx
Hawke Xb 30 pro
Re: Rebolt quiver
In my experience the expandables need 2 grippers because you can't "bury" the tip in the top without disturbing the band or o ring .
Fixed blades will do fine with one gripper as long as the tip is secured in the hood.
This year l went with the catquiver crossbow backpack very glad to get rid of the crossbow mounted quiver not missing it one bit.[url=https://postimg.cc/dL9C8HsY]Image
nchunterkw
Re: Rebolt quiver
vaXbow wrote:
Fri Jan 07, 2022 12:23 pm
Can you show a pick of it mounted to the bow?
[email protected]
mchurch
Re: Rebolt quiver
Post by mchurch »
My micro 380 came in last night. The rebolt quiver looks like it's made by tight spot. It does have s rear gripper and little finger like things in the hood to grab the tip of the broadhead/field point. I think the g5 deadmeat would be ok if you slid it in carefully. I'm going with the grim reaper razortip for now since the tip extends past the blades and the blades snap back in place with the spring system
Excalibur Revx
Hawke Xb 30 pro
