[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Configurator.php on line 5202: file_put_contents(./cache/production//s9e_renderer_34dc1ccc8ca5951b30a74bb414cf321ffe68769a.php): failed to open stream: Permission denied [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result Zodiac Repair - Excalibur Crossbow Forum
When i put the Zodiac in the water after ice out this year the retaining nut on one of the inflation valves somehow worked it self loose. The nut is inside the tube and secures the threaded valve spindle against a flange which is part of the valve body and a gasket to seal the hole. The boat has 6 chambers - 5 in the u-shaped tube and one in the floor. The valve issue only affected one chamber but awful hard to get on plane with a deflated chamber.
So today i went at the repair and after scratching my head for a bit and throwing back a few a beers came up with a strategy to find the nut inside the tube. I ended up strategically hoisting the tube so that the valve hole was at the lowest point in the chamber and hoped the nut would naturally end up at or close to that location. Had to use my homemade cantilever lift that i normally use to lift the dock into/out of position. Worked like a charm:
The open hole sans valve and nut:
The strategic hoist:
The nut visible inside the hole after lifting and falling into place:
Repair done and seaworthy once again:
I think you got really lucky, really lucky....this time.
Might take you a case or two of beer next time and lots of cursing!
The spindle holds the nut in place. I get that. What holds the spindle in place when there's no nut? Keep an extra spindle in your back pocket when you go fishing?
X2 on what Normous said!
Maybe you should buy a 649 ticket?
I can just picture bouncing and hanging a big inflatable boat trying to align a loose nut nut lost in the chamber.
More beer
