i take out the 2 screws that are on the bottom of the stock. one is on the forend and the other right behind the trigger guard.
then try to take it apart but the stock is still attached to the rest of the bow rosk solid. is there a screw im missing or is it just a tight fit?
how to remove the stock?
Thats the only screws that hold the stock on. My stock was sticky and I used a rubber hammer to loosen mine. A good whack or two on the rail and it came right off.
Digger
Digger
Digger
2-1984 Relayer,
2-1992 Wolverine
Vixen, Steddy Eddy, Varizone
Martin Rage
Martin Jaguar
PSE Infinity
2-1984 Relayer,
2-1992 Wolverine
Martin Rage
Martin Jaguar
PSE Infinity
Digger is right the factory stock is tight , just be careful not to damage the trigger when you remove or replace the stock.
Mark
Mark
Exomag ,Exocet,Micro 335
Scorpyd Ventilator
Gold tip laser bolts, Zombie Slayers,Spynal Tapp
Slick Trick, Rage, Magnus bullhead
Danny Miller Strings
Shoot a big one, Let the grunts walk
Scorpyd Ventilator
